Old 05-17-2007, 07:42 AM
PTAddict PTAddict is offline
Originally Posted by 96z28ss
Reason I asked was I just ordered a mcleod SFI bellhousing for my car and it seems to be a universal unit and it has starter provisions on both sides which can effect your exhaust routing if you install one at a later date.
Steve has one on Penny and he said it make the driverside exhaust routing a bit tricky.
I've read some disturbing things about the late-model F-body version of the McLeod SFI bellhousing over on LS1Tech.com - seems there are some unexplained issues with alignment or something else damaging the trans.
In my case, I decided to use the stock bellhousing with a tailored bellhousing blanket from these folks:
http://exoticmuscle.com/catquery.php...L=SAFETY#F6800
(scroll down, second from bottom).
The blanket is probably not technically NHRA legal, nor is it probably as absolutely safe as an SFI bell, but it's certainly safer than nothing and has the additional advantages of much lower weight and no exhaust clearance issues ...
Old 05-28-2007, 10:30 PM
XcYZ's Avatar
XcYZ XcYZ is offline
The motor is completely finished and set in the car, ready to fire. Working on the power steering, Hydroboost, and fuel system plumbing. I have the computer, harness, radiator hoses, etc, everything I need to fire it up. It won't be long now, but I doubt I'll push to fire it before Power Tour. I'm pretty stoked, had to share a few pics.
My LS7 69 Camaro
Old 05-28-2007, 10:43 PM
HotRod68Camaro's Avatar
HotRod68Camaro HotRod68Camaro is offline
that is awesome. great job on it. Nice MAF you have there.
Kyle
Lateral-g Moderator
Very cool.
Old 05-28-2007, 11:03 PM
murtah's Avatar
murtah murtah is offline
Looks awesome. Is that Stenod's intake tube?
Old 05-28-2007, 11:29 PM
awr68's Avatar
awr68 awr68 is offline
Looks killer!! Good to see progress!!
What are you doing to vent the motor? Can something other than valve cover vents/fittings be done??
Tony
'68 Camaro
Old 05-28-2007, 11:44 PM
jonny51 jonny51 is offline
Nice work Scott
Old 05-29-2007, 06:28 AM
XcYZ's Avatar
Jim, I fab'd the intake plumbing with 4" mandrel bend steel. I spray bombed it satin to see if I wanted to go that route or possibly silver. After seeing it in satin, I'll have a friend of mine do a little body work to it and spray it.
Tony, there's a breather in the valve cover that will be plumbed to the remote breather/separator tank.
My LS7 69 Camaro
Old 05-29-2007, 06:31 AM
rich-allen's Avatar
rich-allen rich-allen is offline
Looks great Scott!
The welds on the dry sump system look sweet too!
Old 05-29-2007, 06:58 AM
awr68's Avatar
That's what I want to do as well, but not sure if I can package a breather tank and still keep the fire wall uncluttered with everything else that is going on. I can't put it next to the headlight due to the IC plumbing...time will tell I guess.
Tony
'68 Camaro
