Closed Thread
Old 03-25-2010, 12:58 PM
fleet's Avatar
fleet fleet is offline
Congrats Todd.
Old 03-25-2010, 01:24 PM
So is it falling on it's face when you stomp the pedal? Or as you "ease" into it?
You're right - if you already bumped the squirter up - then you could be masking a lean primary... usually I'd bump the squirter and or power valve if it "hesitated" as I jumped on it... because it's just there to help the "transition" as you open the blades up quickly (adding fuel to "richen" with no vacuum).
Typically - you divide the vacuum reading in half - gives you a good power valve size.
Lean - usually feels like you're running out of gas or a "flat feeling" to the pedal... and or a lean "miss". Funny how many people chase the ignition system when they're really feeling a lean miss...
I HATE carburetors... :>)
  #1403
Old 03-25-2010, 05:11 PM
Payton King's Avatar
Default I am excited for you Todd
Glad to see it all come together. cannot wait for more updates
  #1404
Old 03-25-2010, 05:13 PM
BTW - Todd - my explanation wasn't really for YOU ... but maybe others that are reading the thread and working out their own carb issues... Not that I know what I'm talking about! I'm an EFI guy!
EEEEEEEEHHHHHHHHAAAAAAAA
  #1405
Old 03-25-2010, 06:41 PM
skatinjay27's Avatar
damn i was on that side of town today too!
AJ
  #1406
Old 03-26-2010, 10:06 AM
BBC69Camaro's Avatar
Sounds like fun! Glad things are coming together for ya Todd
  #1407
Old 03-26-2010, 01:47 PM
The highs and lows of building hot rods. I had a severe hesitation say 1/8to 1/2 throttle. I changed squirters, power valve, adjusted floats and finally bumped the primary jets up 4 and it ran great. So I bring it home and the idle starts getting erratic. Put the vaccum gauge on it to adjust the idle mixture screws to no avail. Thought mayble the new power vavle was opening at idle. I finally figure out that the primary venturis are dripping fuel usually meaning the floats are to high but I set them dead nuts. I pulled the site hole plug and theh primary was to high. Strange, so I reset it and it's doing it again. I watch the fuel in the bowl running and it's to low now. I finally figure out the needle is not moving freely in it's bore. (Possibly debris)So I finally get it running great and the needle craps out. To say I was pissed was a major understatement Anyway, I grabbed a new needle/seat, float, and gaskets just to be safe and bumped the jet up .001. I'd give it a 9.5/10 now. This car has never run this good. Changes I made to make it happen:
PV: 4.5 to 7.5 to 4.5 to 7.5 (Higher vaccum on this engine)
Primary Jets: 71 to 77 to 78
Front squirter: 32 to 37 to 40 back to 37
Rear Squirter: 37 to 40
Replaced needle/seat/float/gaskets
So another hands on Holley tuning experience. My garage smells like a gas tanker and one of my neighbors came over to complain about the noise. I've been working on this thing so long and much she thought I was running a shop!
  #1408
Old 03-26-2010, 03:06 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Awesome job Todd.
(You should build some cars out of your garage. You'd make some killer money. You know what you're doing, or at least, pretend you do!!)
  #1409
Old 03-26-2010, 03:11 PM
I'd go broke working on these things. It takes 5 times longer than anyone thinks to do anything. Plus I'm an anal bastard. Eventually I may start taking on a project or two per year but I'll have to move first and the client would need to be very patient and loaded. I'm in no hurry to sell this one and start over. In fact, I doubt that ever happens. I work on it for fun but mostly neccessity. I'm sure it doesn't look that way but I'd rather be racing or cruising anyday. It just never ends with these which I'm OK with most of the time. LOL
  #1410
Old 03-26-2010, 03:26 PM
g356gear's Avatar
g356gear g356gear is offline
Hey Todd, in my experience, usually when you make hp jumps like this, you find the weak links in the powertrain pretty quick. Are you worried about the TKO 600 tranny handling past 500-600 ft.lbs?
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Closed Thread
