Old 02-16-2014, 01:25 PM
GPR's Avatar
GPR GPR is offline
Yesterday I taped the grille and sprayed it semi gloss black let it dry over night and installed today
Rusty Gillis
Gillis Performance Restorations
Port Richey Fl
www.gillisrestorations.com
Old 02-16-2014, 01:36 PM
76orangewagon's Avatar
76orangewagon 76orangewagon is offline
Looks good, especially with the black hood...Of course, you probably knew that already, that's why you did it. Keep the pictures coming.
Old 02-17-2014, 07:06 AM
GPR's Avatar
GPR GPR is offline
Someday I plan on spraying the hood red.
Rusty Gillis
Port Richey Fl
Old 03-23-2014, 11:04 AM
GPR's Avatar
GPR GPR is offline
I forgot to take a photo of the front bumper showing all the surface rust and dents. The rust and chrome was ground and sanded off and epoxy primed. Had to do a little bodywork
Epoxy primed again
Sanded
Slick Sand
Block sanded with 180 and epoxy primed black so I could see if there were any imperfections
Sanded again and epoxy primed white
Three coats of SPI red next day three coats of clear
Sandblasted bumper bolts before priming and painting
Rusty Gillis
Port Richey Fl
Old 04-24-2014, 04:16 PM
GPR's Avatar
GPR GPR is offline
The rear bumper needs a lot of work
After straighten, welding and a lot of grinding and sanding I sprayed at least 3 coats of SPI epoxy and started the bodywork
After a few times of block sanding and priming I sprayed 3 coats of SPI Red the next day 3 coats of SPI Universal clear
Rusty Gillis
Port Richey Fl
Old 04-24-2014, 04:33 PM
66fury's Avatar
66fury 66fury is offline
quick question.i see you put polyester primer over epoxy and i have seen the mepk eat or soften the epoxy causing lifting and failure.i never used spi and usually use dp40.the poly doesnt soften the epoxy at all?
Old 04-24-2014, 04:39 PM
GPR's Avatar
GPR GPR is offline
I've never had that happen and have been doing it since 2005 using SPI epoxy.
Rusty Gillis
Port Richey Fl
Old 04-24-2014, 05:22 PM
Glad to see this project moving forward!
Looks really great Rusty - but then --- you already knew that! LOL
Old 05-07-2014, 06:36 PM
GPR's Avatar
GPR GPR is offline
Autometer Elite tach and gauges installed. You can read all about the install in the August issue of Modified Mustangs & Fords magazine
Rusty Gillis
Port Richey Fl
Old 05-07-2014, 07:49 PM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Very cool car Rusty,cant go wrong with red
