Old 04-08-2013, 07:54 AM
Thus the foot pedal... for controlling your amperage. Your eyes are the monitor...
Old 04-08-2013, 08:42 AM
Sieg's Avatar
Sieg Sieg is offline
Once I get those sync'd up.............
Little personalizations are helping a lot also. Hand props of varying heights, a taller stool, clamping fixtures, etc. I'm finding I can't have too many "custom" accessories. Anything that improves vision, range of movement, and angle of attack......
Old 04-08-2013, 08:45 AM
EXACTLY!!!
It's all about freedom of movement - or travel - while being able to be unwavering... I find that if I'm moving too slow -- the weld will wander etc. So once I get cranking I just want to make that puddle travel.
Old 04-13-2013, 07:12 PM
Sieg's Avatar
Here's a decent video I stumbled across today.
Old 04-13-2013, 07:49 PM
Good video!
My problem is I watch the videos etc -- but by the time I go to weld something -- 8 months have passed and damn if I can remember what it was I was supposed to do! I then go to the internet and try to find the info...
That's the difference between the us and the guys that weld all the time.
Old 04-13-2013, 08:32 PM
Sieg's Avatar
Good video!
If you have a YouTube account there's a thing called "favorites" that you can create a TIG Folder and add the videos to or just add the URL to you browser's favorites............
You can get even............latest attempt at TIG
Old 04-13-2013, 10:22 PM
Hard to tell what size that steel is (3/8th or 1/2") -- but to weld that without a water cooled torch... Dude! You da king of handlin' da heat!
Old 04-13-2013, 10:33 PM
Sieg's Avatar
It's .25" and it gets the paws a little warm!
Two more attempts......
I'm guessing the speed is a little slow........possibly over penetration?
Thicker is easier.......should have started on that a long time ago.
These weld are with 1/16" tungsten and rod, 110-120 max amps.
Old 04-13-2013, 10:47 PM
You know you can check settings with the Miller weld calculator right??
So that weld is called a FILLET weld... and on .25 (1/4") steel ----
Miller calls for 1/8th Tungsten -- with a 1/2" torch cup -- 3/16" fill material -- 250 to 325 amps -- 13 CFH gas flow -- with a welding speed of 5" per minute.
My little Miller Dynasty 200 DX won't even go that high...
Old 04-13-2013, 10:49 PM
Oh ----- I forgot.....
It still is looking like you're gaining some skills....
It isn't that easy you know.
