Old 04-03-2012, 08:45 PM
Sonar Chief's Avatar
Originally Posted by makoshark View Post
Is your car an RS?
No, but the front fenders are NOS RS fenders, I'll have to modify them a little
Old 04-03-2012, 08:48 PM
orangevert's Avatar
orangevert orangevert is offline
SonarChief do you need a rotisserie?
The car is looking good, Lots of great metal work.
Thanks Kirk
Kirk
67 Convertible LS7 BBC 542HP.540 TQ
400 Turbo, 12 bolt posi, 13"12'' CPP Disc, Hotchkis connectors, belly pan.. Hush matt. 3" mandrel bent and load of other stuff.. More a show an Go..
Old 04-03-2012, 08:49 PM
makoshark makoshark is offline
Don't wanna run the RS setup? I love the RS grill look, but I understand not everyone does.
Old 04-03-2012, 09:02 PM
Thanks Kirk
Kirk ... eventually I'll need one. Do you have one?
I have to build a frame jig first and weld the cowl and the tubs in first and then she'll be ready for a rotisserie to do the underside.
Old 04-03-2012, 09:04 PM
I think I like the non RS version better, steady the course
Old 04-04-2012, 07:11 PM
orangevert's Avatar
Yes, If i have it when you need it PM and if you want to drive to Denver you can use it.
Kirk
Kirk
Old 04-06-2012, 04:52 PM
Thumbs up Door looking better
Kirk
Kirk ...PM sent.
Scuffed the POR15 and put two coats chassis black on the drivers door, came out great I'm glad I took the skin off and refinished the inside ... don't have to worry about rust no more.
Hey is some car porn!
Looking better!
Nice sheen and protected from rusting
Thanks for looking, I'm out to patch that hole in the rocker panel.
Old 04-06-2012, 09:41 PM
Thumbs up Garage time ...
Nothing special just patched the rocker panel hole, still need to finish it tomorrow, that's another day.
Patched the hole
Thanks for looking!
Old 04-07-2012, 07:20 AM
Steve68 Steve68 is offline
the pics are great, what are you using to clean the door jambs,
I need to redo the Nova body, I like how yours is coming out!
I like the RS look, my car will be getting the RS upgrade, have all the parts!
Old 04-07-2012, 09:19 AM
Steve ... I use a nylon abrasive circular disc purchased at Harbor Freight for the jambs and the firewall, I think the 4 inch is 4 bucks or so. There is a 80 grit coarse and a 120 grit, attached to a drill and away you go! It's time consuming but does the job
Good luck with your 68RS.
