Old 02-24-2014, 09:09 PM
Jon69RagTop Jon69RagTop is offline
Default I understand your pain
but let me say that car looks awesome. I absolutely think you nailed the rim/tire combination. I'm a fan of slightly taller sidewalls as you are, perfect set up IMO.
now get back to work!!!
Old 02-25-2014, 06:21 PM
grif54 grif54 is offline
Wow! I just read through the hole build and I am very impressed. It looks like you did it all in your garage also. I would really like to use an LSA but am a little bit intimidated by all the extra plumbing involved. The car looks great
Old 02-25-2014, 09:30 PM
It looks awesome..
Old 03-06-2014, 03:15 PM
kwhizz's Avatar
kwhizz kwhizz is offline
A simple issue to pass along for others to not make the same mistake as I did.......I used Fuel line for the transmission cooling lines to the radiator.......after blowing holes in the lines (3 times) and after the last time the car had to be brought home on a Flatbed.....I didn't know really what the Heck was going on.......I called RPM transmissions and after explaining what was going on......he explained that you can't use fuel line for this purpose......It seems the trans fluid attacks and weakens the Rubber used for fuel lines......the trans he built for me has about 300 PSI line pressure when put in reverse and that's why I was having these problems.......It was blowing thru the hose at it weakest point.........So....I already replaced the front section of lines (from the starter forward) with hard lines........and I was going to finish the rest but it seems me and tube benders don't get along.......so after going thru a bunch of hard lines I went and bought some correct trans rubber hose and installed them and everything is now fine........Now maybe I can make it to the alignment shop without the trans line blowing out......LOL.......
On to the last Issue that I had to deal with was setting the pinion angle.....The Ridetech set-up is great .....But.....because of the little extra angle of my engine trans combo when I tried to adjust it using the upper adjustable arms........It just rolled the rear end back into the Coil Overs..........So.....as the lower arms are fixed length and non adjustable.......I talked to the Tech guys at Ridetech (Great Guy's) and what I did was bought threaded Bungs and Rod Ends........So.....we cut off the ends of the lower arms and welded in the new bungs with the adjustable Rod Ends........So.....I figured out the angles and how much shorter the lower arm needed to be and adjusted them and put everything back together.......Bingo........hit it the first time......and when I ordered those parts I also ordered the rear sway bar assy.......so I got everything installed and finished.......Now we just need some dry Salt free roads to get the alignment completed......Get the exhaust system installed.........Get the car to Donnie at Frame-up.......Then off to Stefano at Nickey for the Tune.........
Ken
Old 03-06-2014, 09:47 PM
Zoomin Zoomin is offline
I know you haven't had much seat time, but what are your initial impressions on ride and handling?
I appreciate all the lessons learned too.
Old 03-07-2014, 05:32 AM
kwhizz's Avatar
Too soon to tell.........Front end is still not aligned and I have no idea yet where the shock valves are set......
Old 03-07-2014, 07:23 AM
coolwelder62's Avatar
Chevelle truned out great.
Old 03-07-2014, 07:28 AM
1965_SS's Avatar
1965_SS 1965_SS is offline
Ken
Ken, your car turned out amazing!
The problem you had with your lower arms is what is making me lean towards using Chassisworks g-Link control arms, they are adjustable.
_________
1965 Chevelle SS
Project Build
Old 03-07-2014, 06:48 PM
glassman's Avatar
glassman glassman is offline
Now, see how easy that was! lol.
Some times i think we dont run a race when building these things, we run a "hurdle" race....obstacle after abstacle....
Mike
Old 03-07-2014, 08:00 PM
chichirone's Avatar
chichirone chichirone is offline
Ken, your car is looking awesome. The stance is kicka$$. I experienced the same issue with the Ridetech rear 4 link on my 69 Camaro. We used the same fix as you on the lower bars and it made a huge difference. The greatest issue was going in and out of a driveway or over a bump while turning. The tires would rub the front edge of the rear fender. We attempted multiple pinion angle fixes and after tearing two trim pieces off the rear fenders and messing up the paint, we finally figured it out with the help of the Ridetech guys. In my experience, Kyle Nichter and the tech team were very responsive and helpful throughout resolving the issue. Some of the BEST customer service in the industry.
Jay
1973 Trans Am "KLRBRD"
1969 Camaro SOLD
2014 Stingray Z51 SOLD
