Old 08-22-2007, 07:40 AM
Rob07002 Rob07002 is offline
No problem, glad to help.
You may really want to consider the Alston G-Bar setup though. For what you'll have in a leaf spring setup with a watts linkage you can do the g-bar and have more adjustability.
I was in the same boat as you a few months agao till I saw the g-bar and talked to Frank at Prodigy. I sold my DSE stuff and didn't look back.
I haven't driven the car yet, but it's installed and all I can say is wow! It's a thing of beauty and quality.
Anyway, food for thought.
Rob07002
Old 08-22-2007, 02:02 PM
Clockwork's Avatar
Clockwork Clockwork is offline
Originally Posted by Rob07002
I think the side w/o the bushings are the shackle side and the idea behind it is that most will install their own desired bushing, whether poly or Del a Lum.
Most I know run rubber up front and the GW bushings out back.
Just saw this thread was wondering if it is OK to use the del a lum bushings up front as well?
Dean
Old 08-22-2007, 04:13 PM
Yep. We use them all the time front and rear.
Tyler
Old 08-22-2007, 04:26 PM
Clockwork's Avatar
Tyler
Cool, cause that's what I'm running and all seems good so far.
Dean
Old 08-23-2007, 12:51 AM
Could you post some pics? I havent installed anything yet..
63 Z06
Old 08-23-2007, 08:11 AM
I don't have any of mine in the car, but here is a link to a thread by Frank at Prodigy. https://lateral-g.net/forums/showthread.php4?t=10665
This thread, https://lateral-g.net/forums/showthread.php4?t=10488
And this thread https://lateral-g.net/forums/showthread.php4?t=9784
Should cover all the bases. As you can see it's been discussed quite a bit on here.
This is a pick if the Air-Bar, same thing but the G-Bar has coilovers.
http://ridetech.com/productinfo/prod.../ABAR20100.jpg
It's a VERY nice setup and almost entirely a bolt-in kit.
Give Frank at Prodigy a call he he'll talk you into it in 2 minutes. He can also make you a nice deal on the kit through his GP Superstore.
Truthfully, after seeing it installed I would never go back to leafs again.
Rob07002
