Old 08-15-2007, 12:10 PM
Default What bushings in DSE 3" drop leafs???
I just notice at my new DSE drop leafs came without bushing at the other end ???????? And other has bushing installed. What is the idea behind it?
Is it front or the shackle side ? And i am useing DSE offset shachkles too.
63 Z06
Old 08-15-2007, 02:11 PM
Rob07002 Rob07002 is offline
I think the side w/o the bushings are the shackle side and the idea behind it is that most will install their own desired bushing, whether poly or Del a Lum.
Most I know run rubber up front and the GW bushings out back.
Rob07002
Old 08-16-2007, 12:19 PM
Thanks! I wonder why they didnt told me this at DSE when i placed my order
63 Z06
Old 08-16-2007, 12:29 PM
No problem. They (DSE) probably assume everyone knows this already.
I have the GW Del A Lum shackle kit if you need it. Brand new for a good price.
Rob07002
Old 08-17-2007, 11:28 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Hotchkis are the same way.
Old 08-18-2007, 08:12 AM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
I'm gonna run the old factory style rubber bushings.
Chris
Old 08-19-2007, 02:15 AM
I think i have been askind this before but will the leafts only keep rear end from moving side to side when cornering hard? I know panhard bar wont work on lefs but is there anyting else to do? Or is there any need to do anything ?
63 Z06
Old 08-19-2007, 09:21 AM
MarkM66's Avatar
Yes, for the most part.
Some have run a p/h bar with leafs.
Old 08-21-2007, 11:26 AM
You can check out the Fays 2 setup.
www.fays2.net
Rob07002
Old 08-21-2007, 11:07 PM
www.fays2.net
Thanks Rob, i havent thought watts link like that before. Great idea!!!
63 Z06
