Old 06-08-2005, 02:24 PM
ryans67deuce's Avatar
ryans67deuce ryans67deuce is offline
I'd recommend Line-X over the "rhino linings". Line-x is more of a consistent application where rhino stuff gets "clumpy" and not as attractive. Line-x is some tough @#$$ too, I took a hammer to it and barely left a mark. No chips or cracks, just a scuff mark....
Ryan
Old 06-08-2005, 06:16 PM
Derek69SS's Avatar
Is there any way to strip this stuff off 20 years from now, when my car needs another resto? I've been considering it for my undercarriage and inside the trunk.
Old 06-08-2005, 08:47 PM
almcbri's Avatar
almcbri almcbri is offline
I sprayed the bottom of my 68 with reflex. which is a twin of rhino, but better. Pro's sound deadening, no rust, cons-weight. Weight isn't a issue for me. The underbody looks perfect, great finish. I would do it again on my next project.
Andrew
Old 06-09-2005, 08:13 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Originally Posted by TravisB
I have never done it myself but I know the Sick Fish that Troy built was coated on the bottom...very clean & sanitary
You are correct sir. It was stated in the "Build Book."
Old 06-14-2005, 07:20 AM
TravisB TravisB is offline
Ya I talked to Troy and Dan Holohan at Indy they use speed liner w/black base coat mixed in it!
Kenny Davis Hot Rods
Old 06-14-2005, 09:18 AM
Protour_Pinto Protour_Pinto is offline
I plan on doing the bottom of the Pinto withthe Line_x brand and the inside with Lizzard Skin. I want to keep the heat out and make it a better ride inside.
