Old 11-08-2007, 07:00 PM
Blown353 Blown353 is offline
Originally Posted by musclecarjohn
All good advice but a 4" b/s on an 8" wide wheel will push the tires too much into the fenders.I bought that same set-up from a friend who mis-ordered them for his '69 Camaro and they are too close to the fenders for my tastes.
Odd. As I said, my 17 x 9.5 wheels put the outer lip at the same spot as a 17 x 8" with 4" of backspacing would and I have *plenty* of room up front.
Tire clearance depends on your alignment too. I run -0.75 degrees of negative camber right now which helps with front fender lip clearance.
It's all fine to analyze this, but the only way to make sure what is going to fit YOUR car is to go out and mockup and measure YOUR car. Even models of the same year vary from car to car. Assembly line tolerances 35-40 years ago aren't what they are today!
1969 Chevelle
