Old 10-24-2007, 07:30 AM
Birdman's Avatar
Birdman Birdman is offline
Default Which tools would you guys recommend?
OK, since I'm setting up here and trying to get all the tools I need, I thought I'd see what you guys would recommend. Here's what I've got:
About every socket needed
About every screwdriver needed
About every pliers and adjustable wrench needed
Lots of crowbars and prybars
Several drills (still need a cordless one)
DA sander
HVLP sprayer
Impart wrench
Air ratchet
Grinder, angle grinder, and cutoff tool
Sawzall
Chop saw
Rotisserie
Lots of jackstands and a good jack
Powdercoating setup with oven
MIG welder (coming soon)
Lots of drop lights and things
And probably some other stuff I can't think of. What tools do you guys think I should get my hands on?
1998 Trans Am - BMR drop springs, BMR LCA relos, Bilstein shocks, Sportmax 18x9.5 wheels, lots of goodies, 6-spd swap, lQ9 swap
1968 Camaro (Patriot Dream project) - Iron LS1, T56, lowered and nitroused PT machine
PatriotDream.org - Help make a soldier's dream come true
Old 10-24-2007, 08:04 AM
class67's Avatar
class67 class67 is offline
You may be a ways off from needing this, but how about:
heat gun
wire splicer / crimper
butt connectors
solder
soldering gun
heat shrink
test light
wire loom
Old 10-24-2007, 08:06 AM
Birdman's Avatar
Got all of that already.
Old 10-26-2007, 03:09 PM
400bird 400bird is offline
blasting cabinet?
Old 10-26-2007, 03:29 PM
deuce_454's Avatar
a plasmatorch i couldnt live without mine... a good stationary grinder... one with long abrasive bands... a TIG welder, tube bender, a lathe.... a lift an oxy acetylene torch... and the list just goes on...
Jake: Hit it.
Old 10-27-2007, 07:44 AM
RaceMan's Avatar
RaceMan RaceMan is offline
How about a good press and a parts washer , I use both of mine.
SPEED IS ALL YOU NEED !!!
