Old 12-12-2007, 03:03 PM
Hi Vin,
For the MS series of connector you are looking at (MS27656T13F35S or P, which is actually a MIL-C-38999 Series connector) - check here.
http://www.newark.com/jsp/search/pro...sp?SKU=91C3824
Open the Data Sheet link at the bottom of the page and look on page 3 of the PDF doc (page 117 of the Cannon catalog lower right corner) for the different configs of that connector that are available. I'm not sure how many wire connects you need - and the gage for each required, but if you scan through you should be able to find the one that matches your needs and pick that part number.
See catalog page 132 for the contact arrangements
See catalog page 134 for the pin part numbers for the wire gage you want (looks like 12 is largest they go for pins/sockets in this product line).
Looks like most of the S or P bodies are about 50 bucks. Then you will need a 'backshell' for both sides.
Hit Newark with the part numbers and you'll see their on-line prices.
Here's one of my current vendors on connectors:
http://www.wingselectrosales.com/connectors.html
Old 12-12-2007, 05:48 PM
dhutton dhutton is online now
Here's another source. The virtual catalog that can be accessed on the catalog tab appears to be more detailed than the Newark one.
http://www.alliedelec.com/Catalog/Indices/Products.asp
Don
Old 12-13-2007, 01:31 PM
BigVin BigVin is offline
Don and Jim
Thanks for your time good info but I have more ?s. When I buy 91C3824 from Newark do I get a male and female connector or do I need two part numbers.
When I order pins do I order Mil-C-39029/58 or /56 and whats with the color bands. What back shell do I get type P or f and they don't have 90 listed. And what are the numbers under the contact arrangement.
thanks again Vin
Old 01-06-2008, 07:06 AM
JimM JimM is offline
I'm also looking for a bulkhead connector like this.
I'll need to pass 32 or so 18 gauge wires.
The milspec stuff is real difficult to understand. There is a huge variety...lol.
Each part is ordered separately. bulkhead receptacle, plug, inserts, seals, male and female pins, all separate.
This website has a lot of good stuff, including a 30 pin weatherpack complete kit, but they don't give dimensions, it looks kida big.
http://www.eficonnection.com/eficonn..._junction.aspx
What solutions have others used?
I REALLY do not want to hardwire my EFI harness through a grommet.
Webmaster (lol)
68 Camaro Vert, SS clone, #'s matching 383-TKO500
04 Silverado SS, 93 Polo Green Vette
My Camaro Board
http://www.Jimragtop.com
Jim's Blog!
Old 01-06-2008, 02:40 PM
Kokamo Kokamo is offline
Jim, I will agree with you on the no grommet thing, but for the price of the big mill-spec connectors and the rediculous amount of studying to even figure out what you need, I was looking around on Summit and found somthing called "Seals-It". It is a grommet, and it is a very good grommet. I ordered a one for a fuel line to go out of the trunk and under the car, one for the battery cable to come out of the trunk and under the car, used another for the main battery supply to the electrical box inside the car from the starter motor, then used the last one on the big harness from the LS1 engine to the computer inside the car.
The one for the harness is a two piece design. You can get it in various sizes, but the one I needed, they didn't have, so I simply ordered a blank one with no hole.....I made my own to fit 76 wires and the insulation thru it. I made the custom block off plate on it as well. It looks good and I think it's going to work pretty well too.
Here is a pic........
http://i198.photobucket.com/albums/a...4/100_2766.jpg
http://i198.photobucket.com/albums/a...4/100_2765.jpg
http://i198.photobucket.com/albums/a...4/100_2768.jpg
Hope this helps out someone,
Joe
Old 01-06-2008, 06:40 PM
I've seen those, Joe, and they do look nice, for a grommet, but I want a connection. Seems everytime I touch a weatherpack connector, I break off the locking tab! Also seems like the motor is out of this car once a year...
Car is a keeper, and a driver.
I wanna just unplug it. Engine harness stays on the engine!
Webmaster (lol)
My Camaro Board
Jim's Blog!
Old 01-06-2008, 09:02 PM
I gotcha, I totally understand. Good luck on your search bro.
Joe
Old 01-07-2008, 06:16 AM
Joe
Hello Joe!!
For me those look just what i have been looking for!!
Can you tell me the overall ( outside ) diameter of them ?
63 Z06
Old 01-07-2008, 02:04 PM
Originally Posted by Bowtieracing
Hello Joe!!
Sure, when I get home from work and go out and work on the 69 later on tonight I will get that measurement for you.......I just need a reminder.....send me a PM later on this afternoon.
Joe
Old 01-07-2008, 05:05 PM
I've come across those grommets before, or something very similar. There's a pretty big variety of sizes and styles. I found the link in my favorites, enjoy!
http://www.sealsit.com/
Webmaster (lol)
My Camaro Board
Jim's Blog!
