Old 12-10-2007, 02:19 PM
BigVin BigVin is offline
Default Mil-Spec bulkhead connector
I'm looking for someone who builds Mil-Spec bulkhead connectors like Wires to pliers build or where I can get the same parts as they used to build my own.
PLEASE HELP
Old 12-10-2007, 02:50 PM
Howdy,
Check this link for the standard manufactures of bulk head connectors.
https://lateral-g.net/forums/showthread.php4?t=9405
Jim
Old 12-10-2007, 03:44 PM
dhutton dhutton is offline
I know this isn't mil spec but here is one that's a weatherpack and seems like a good deal for the money:
http://stores.ebay.com/PERFORMANCE-P...QQftidZ2QQtZkm
Don
Old 12-10-2007, 06:08 PM
Jim
I've seen that thread and have been on the Deutsch web site. I think I need a HD30 24-18 but it's all Greek to me. And will they sell just one connector.
Vin
Old 12-10-2007, 07:17 PM
Here's a link to a catalog of cables and connectors. I saw circular mil spec connectors taking a quick look. I've ordered from them with a credit card online. You can check stock by clicking on the part number. Let me know if I can help you figure anything out.
http://www.newark.com/jsp/content/pr...display=single
Don
Old 12-10-2007, 07:58 PM
Hi Vin,
They will sell just one connector as we often replace a single connector due to oil or fuel ingress. The hyd fluid we use in aircraft (Monsanto skydrol) will swell and/or soften the rubber in a connector after a while - so we end up replacing them at heavy check. I seldom buy direct from the manufacture as we buy our wire, connectors, pins, pin tools and such through an aircraft supply group. Yell if you want a contact.
Jim
Old 12-11-2007, 03:38 AM
Don
Thanks for the link I think the one I need is on page 8 22 pin #91C3824 and 91C6856. My ? is can I use different gauge wire in the pins.
Jim please give me a contact and what do you think of those part #s
thanks agian Vin
Old 12-11-2007, 03:59 AM
Jim
Or the Deutsch HD30 HDp20 24 shell.
Vin
Old 12-11-2007, 10:42 AM
I'm on it.
For the pins - you will need to specify the wire gage to get the correct pin range. They can supply the correct pin ends that will fit into the connector receiver - and the barrel end has a couple ranges for wire gage size. Normal spread is 20 - 24, then 18 - 16, etc.
Old 12-11-2007, 12:01 PM
Originally Posted by BigVin
Don
thanks agian Vin
If I am reading the datasheet correctly (there is a link when you check inventory) the max wire size is 22 gauge with a max current of 5 amps. The smallest is 26 gauge with a max current of 2 amps.
Don
