Old 12-20-2007, 12:17 AM
The best solution for people that don't want to cut their subframe, have upgraded parts on it already, and want Air Ride is to get the new Speed Tech upgraded factory replacement frame.
You can use all the control arms, spindles and sway bar that you currently use, and then get the ability to bolt on Shockwaves, plus R&P steering. Look into it as an alternative to cutting on your frame.
Tyler
Old 12-21-2007, 09:54 AM
Supporting Vendor
so long as the bags and the dampers are the same, you can use the older QA1 set up front. The bag is the same (6.5" diameter), and the shock length should be the same (if the QA1 version was intended for the First Gen).
Old 12-27-2007, 06:44 AM
darren@ridetech's Avatar
darren@ridetech darren@ridetech is offline
Give us some dimensions on your Shockwaves, compressed & extended.
