Old 12-11-2007, 11:00 AM
Camaro ProTouring's Avatar
Camaro ProTouring Camaro ProTouring is offline
Default How about airride???
I wonder if anybody here have mounted a pair of Air over shocks on a first gen Camaro?? How did i t fit??
I would likte to mount a set of airbags on my -68 but doesnt like the thing that i have to move the shocks to the outside of my control arms.
Thats why il started to look at air over shocks but i still have to cut in my subframe to get them in there.
I have seen that some hot rods have mounted these up side down. Is it anyone that tried this and can tell me how it works!!
Swedish dude who likes old american cars...
This is what i got in my garage!!
Camaro SS -68 "Streetcar"
Camaro -68 "Racecar"
Ford F100 -56 Pickup
Old 12-11-2007, 01:18 PM
Supporting Vendor
there is a minimal amount of cutting required to fit our (Air Ride Technologies) Shockwave units into a first gen Camaro. GM rolled the lip of the subframe around the spring pocket, and that is what needs to be removed as we are using a 6.5-inch air spring that will rub the roll if left uncut. The material removed does not reduce the structural integrity of the subframe.
I'll let "non biased" members post on installation fitment, part quality, and whatnot.
-Britt-
Old 12-11-2007, 01:33 PM
-Britt-
Okey, i still doesnt like the fact that i have cut in the subframe but thats maybe something i cant come around!!
How about mount your air shock overs upside down??? Is it possible??
Like i wrote before, i have seen som people do it but im wondering about the shock, it couldnt be so good.
Old 12-11-2007, 02:21 PM
fesler's Avatar
fesler fesler is offline
we have done a few of these and cutting out the pocket to fit these is no big deal at all. You just have to trim just over a inch for the bag to clear everything. Its not a big deal at all and you will love the imporved ride. Just take your time and mock the bag in the pocket and trim.
dont over cut your pockets, you may need to install and uninstall them a few times to get them perfect. I try to give about a 1/2 inch of clearance so the bags can never rub on anything. Usually you can mount these up or down as Air Ride should agree on here. I have done them both ways and you dont notice anything different about it.
You will love the look and the ride once you get them in there its well worth it.
Chris Fesler
Fesler Built - Scottsdale, AZ
Old 12-12-2007, 12:01 AM
So if its not a problem to mount them upside down, it should be better because then i dont have to cut anything at all...
But maybe its something else that ****s up then... regarding the shocks for example!! Is it anyone that really tried this whit good results.
Old 12-12-2007, 05:48 AM
fesler's Avatar
I think no matter what way you mount them you will have to do some cutting, it might not be as bad one way or the other but usually when doing air you have to cut to keep the bag away from all objects. The other problem I can see you having is the bag might hit the sway bar if mounted upside down and that would be worse. Mock it up there both ways and go through all the suspension movments so you can see if it will clear everything. measure twice cut once it always works out better that way.
Chris Fesler
Old 12-12-2007, 10:51 AM
Hmm... u got a point there... i didnt thought about the swaybar!!
Okey i have to realise that i have to cut in the subframe!!
Thank u guys for your opinions!!
i will post some pictures later when im done!!
Old 12-12-2007, 12:24 PM
A second thougt!!
Is it anyone that have mounted airbags instead of air over shocks and made new brackets for the shocks??
How did you solved it and where did u mount the shock!!
Pictures had been a big help!!
Thanks!!
Old 12-12-2007, 01:38 PM
Supporting Vendor
We have a kit like that (called a CoolRide kit). you can see it here:
http://ridetech.com/productinfo/prod...es/ARF6500.jpg
However, you have the same problem; you'll have to cut the subframe. Same bag, same location, same problem.
The additional problem is if you plan on running wide front wheels they may hit the shock absorber, as it will be mounted behind the a-arms.
-Britt-
Old 12-19-2007, 11:00 PM
68Camaro502's Avatar
68Camaro502 68Camaro502 is offline
Default I thought shockwaves were just a bolt in?
I have some of the larger shockwaves and a new set of the slimmer new shockwaves which i am wondering if I can fun up front cause they are QA1 adjustables from Air Ride Tech.....
BLACK
1968 Camaro RS SS 502 Ram Jet powered by FAST XFI and FAST Digital Dash for monitoring/Data Logging.
TH-350 (Turbo Action) Manual Valve body, Type F fluid.
Dropped spindles with Air Ride up front. 200 shot of NOS
http://s110.photobucket.com/albums/n...lack%20Dragon/
