Old 04-11-2008, 02:43 PM
BBC69Camaro's Avatar
Here are the pictures of getting after-market gauges to fit in the stock carrier that I promised:
Since my car didn't have a Tach, I wanted to move the fuel gauge to the center (bought a resto bezel from Classic Industries), so I cut out the center to match the bezel:
Rear shot of same:
Shot of the Bezel along with the bracket I made to hold the gauge and cover up things:
Shot with the bracket in:
Since the stock carrier can't accept standard aftermarket gauges, I removed the old ones and then proceeded to measure and cutout holes that matched 3-3/8" gauges I wanted to install:
Tach cut out
Continued on next post...
Speedo cut out
I cut out to about 3" and then used a dremel tool to slowly match fit the gauge exactly to the hole (I wanted it to be really snug). I also made a metal bracket to hold both sides together since I was taking out so much of the middle section.
Rear shot:
Mockup with gauges:
Completed Front (polished the stock lenses):
It is hard to tell with the pictures but the Fuel gauge is held at the same angle as the Speedo and Tach.
Rear:
The Carrier is pretty beat up, and I'll address that when I redo the interior as another project (right now want to get the car running).
Old 04-11-2008, 02:44 PM
Other gauges I am going to run:
A Pillar:
Console Pod:
Under Dash:
Anyone know of some good cleaner to use on the console?
Old 04-11-2008, 05:53 PM
DOOM's Avatar
DOOM DOOM is offline
Keep um coming loooooooovvvveeee those 69's !!!!! Was this car on ebay??
Old 04-22-2008, 04:52 PM
GHOSTDANCER GHOSTDANCER is offline
Great job
Old 04-22-2008, 07:40 PM
Not that I was aware of, found this car off Craigslist.
Old 05-18-2008, 08:54 AM
Some progress on the mini-tubbing:
Cleaning off the undercoating (used an angle grinder with cup wire brush, nothing else worked very well) to find and drill the spot welds:
Started cutting the inner tub out with a cutoff wheel:
Passenger Inner tub is out!
Old 05-18-2008, 08:55 AM
Now cut out the upper shock mount, starting to get some real extra space
Bent tabs down that I will eventually spot weld the new inner tubs to:
Side shot of the frame rails getting some attention:
Mini-tubbing is a lot harder than I thought it would be! I have been in the fetal position in the trunk more times than I can count (can't wait to weld like that). I have never really done any metal work like this before, a lot of the cuts are pretty rough and require a lot of cleanup. I'm glad I am doing this as a hobby, otherwise I'd be too slow to get paid for it, lol!
The DSE video has been a good resource as has DSE support. Their products are definitely worth the price due to the good support.
I had test fit the new tubs in (camera ran out of batteries so no pics yet). There is a bit of a gap, but nothing a few c-clamps weren't able to make go away. Started on the Driver's side now.
Been taking a lot of pics, thinking of putting together a novice's guide to mini-tubbing
Old 05-18-2008, 10:42 AM
dhondagod's Avatar
dhondagod dhondagod is offline
Just stumbled across this. MAN! You just jumped right in didnt you?!
Work looks good so far! Youve got to be stoked!
Chris
Old 05-18-2008, 11:23 AM
Coming along great
