Originally Posted by 68protouring454
nice work steve, you need more sway bar and spring up for sure
jake
I have quite a bit of bar already.. 1" solid splined..
And the Springs are 450s.. I'm really thinking it's a shock issue.
In a right hand turn the passengers tire almost lifts.. in a left turn the drivers tire doesn't lift nearly as much. Is this consitent with the front right (pass) side shock being low/out of oil?
I can also adjust instant center by swapping in the the slotted inserts for the upper control arms..
See Bad Penny run the cones:
https://www.youtube.com/watch?v=8GUPPIX-92U
