Old 03-20-2008, 05:43 PM
brownz brownz is offline
I think that the kore3 stuff is real nice i got the rear e-brake setup and front kit for the c6 zo6 brakes aswell but for a 12-bolts looks cool too
Old 03-21-2008, 06:32 AM
ProTouring442's Avatar
Yes! yes, yes, yes, yes! Yeeee-haaa! Yes!
Ok, the point is, I was looking for someone to make these!
Shiny Side Up!
Bill
Old 03-24-2008, 12:55 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Installed the parking brake assembly this weekend. What a great kit.
Parking brake cables will be here this week and that job will be done.
My LS7 69 Camaro
Old 03-24-2008, 02:25 PM
Stang's Bane Stang's Bane is offline
Originally Posted by deuce_454 View Post
Nice brackets... i just dont like the drum in hat system, it always seem to sieze up on street cars, or not work when you need it to.. but on a PT car where everything is maintaines beyond reason i guess its fine...
That is the factory system on 4th gen F-bodies. I have never heard of a problem with them???? Maybe i need to look more
Old 03-24-2008, 04:06 PM
deuce_454's Avatar
its whats on all the volvos ive ever wrenched on.. and it always seemed to be stuck and rusted.... but then again we salt our roads alot...
Jake: Hit it.
Old 03-24-2008, 08:01 PM
ohcbird's Avatar
ohcbird ohcbird is offline
Scott-
Thanks for showing the install; I'm very interested.
What about the rear swaybar? Did you make that?
Jeff
Old 03-25-2008, 11:12 PM
ohcbird's Avatar
Default swaybar
Dooooooooh- swaybar info found on your website... I'll contact Tyler.
Old 03-26-2008, 06:14 AM
XcYZ's Avatar
Sorry Jeff, missed your question. I see you found the answer, though.
My LS7 69 Camaro
Old 03-26-2008, 06:47 AM
DOOM's Avatar
DOOM DOOM is offline
Originally Posted by XcYZ View Post
Yep, I'm running the new big style/Torino bearings, but this kit is available in 3 different 9" housing end bolt patterns.
About $700, depending on options. I ordered a several brake lines from Tobin as well.
Im going to put a 9 inch in my Camaro and yesterday was given a complete set of C6 calipers . What 9 inch housing should I look for ,is one better than the other???
Old 03-26-2008, 06:55 AM
XcYZ's Avatar
I have the Torino style big bearing housing ends and that's what I'd recommend. Its 2.5" housing face to axle flange gives enough room for the DIH parking brake.
Here's what Tobin at KORE told me about his brackets and Ford housings:
As far as applications go, the kit is only compatible with the Big-Bearing Torino style housing and soon to be the Small-Bearing housing as well. The old style Big-Bearing housing with 1/2" T-bolts will probably not happen due to the very short brake offset dimension of 2.36"...it's causing interference issues between components that we may not be able to get around without excessive tweaking.
My LS7 69 Camaro
