Old 05-05-2008, 08:02 PM
CRCRFT78's Avatar
CRCRFT78 CRCRFT78 is offline
Welcome aboard from a fellow G-body owner.
Old 05-06-2008, 09:27 AM
GBodyGMachine's Avatar
GBodyGMachine GBodyGMachine is offline
Originally Posted by malibu795 View Post
i deff would like to build my wagon to hit 1.00g
275 40 17 min all 4 corners
engine is going to be ~550hp BTW its a diesel
think that is a good start...... opinion please
I dont think you will be able to fit a 275 on the front, depending on how low the car is. I have a 255 and it rubs. Let me know if you get them to fit.
What kind of diesel?
Jeff
84 Regal Project GBodyGMachine
[SIGPIC][/SIGPIC]
Old 05-06-2008, 12:00 PM
malibu795 malibu795 is offline
Jeff
6.6 duramax diesel with the t-56 tanny behind it
ill double check my notes and get back on that
Adam Wildman
99 C3500HD dmax/4l85E
79 malibu wagon 468bbc/ t-56/8.8
U.S. Navy 2000-2008
Old 05-06-2008, 12:24 PM
all copied form his postings
I think somebody was asking about 285/40s awhile back.
I am playing around with my corvette wheels and came up with this.
Frame clearance on the inside at the closest point is 1/4"
Offset on the wheels with the 2" spacers is 1/4" negative.
So basically the wheels are 17x9.5 with 1/4" negative offset.
Also, I have aluminum drums.
275/40/17 on 9.5" rim
285/40/17 on a 9.5" rim
"is there clearnce to lower it a couple inches"
his response
Yes, It will come down.
No problem on the rear.
No problem on the front either but at the expence of hitting the upper control arms when the wheels are turned sharp.
I have the front wheels set in alot further than the backs.
The wheels are the same but I used 1.25" spacers on the front and 2" on the back.
No way to put a 9.5" wheel on the front without having some type of problem. I chose to loose turning radius on order to keep them from hitting the outer fender.
that help?
Adam Wildman
U.S. Navy 2000-2008
Old 05-06-2008, 12:27 PM
RobG RobG is offline
Thumbs up
I have a SC&C weld in watts link on the way. I'll post pics once I get it in, it should be a pretty trick piece
I've got a '87 turbo Regal this is going in.
P.S.
Talk to Mark @ SC&C when you get a chance. Super smart guy when it comes to making g-bodies handle like go-carts
Old 05-06-2008, 12:31 PM
here is another
malbiu with a BBC
The front wheels are 17x8 with 4.5 bksp with a 255x40x17. The rears are 17x9 with 5" bksp with a 275x40x17.
question about rubbing his answer
I thought the weight of the big block would make the front end to mushey and then rub on the front inner fender. But none.
Adam Wildman
U.S. Navy 2000-2008
Old 05-06-2008, 12:33 PM
P.S.
cool thanks rob!
i deff to keeping my mind open to good ideas
Adam Wildman
U.S. Navy 2000-2008
Old 05-06-2008, 04:01 PM
that help?
Thats what I figures, no turning radius. Looks bitchin though.
[SIGPIC][/SIGPIC]
Old 05-06-2008, 04:15 PM
rking's Avatar
rking rking is offline
P.S.
I definitely want to see pics of that thing when you get it! I will be starting a 3 link setup on my GN very soon, but Im not sure if their kit will work for me or if Im going to have to custom build one...
Old 05-06-2008, 06:11 PM
i dont know.... but how many current midsize production cars can U-turn inside 40' or ~2.5 lanes of traffic? even a 3rd gen camaro or vettes dont turn this tight.. im talking about almost as tight as civic, cavalier, focus tight..
i know my friends saturn vue takes more space to turn around than my wagon and she has a shorter wheel base
unless you are hitting full lock all the time i dont see it being a problem in 90% of normal street duties
JMHO i wouldnt mind giving up a couple Degrees in steering to acomodate the rims.. might be abel to get some of it back with 9" rim vs a 9.5 since that can still take a 275 tire properly. i have seen pic of a 275 on a 8.5" rim as well.
Adam Wildman
U.S. Navy 2000-2008
