Old 10-01-2008, 01:49 PM
Marcus SC&C's Avatar
Marcus SC&C Marcus SC&C is offline
I don`t have a data sheet for the Camaro handy but the early Mustang units install exactly the same way. If you saw them side by side you`d be hard pressed to tell which was which. Here`s a link to those data sheets. http://www.totalcontrolproducts.com/...MX0_DS_WEB.pdf The Hellwig bar`s links mount just forward of the G-Bar cradle and UCA mounts so there`s no interference. There`s also a frame mounted adj. rate Chassisworks bar for the G Bar for about twice the moolah. Mark SC&C
Old 04-06-2009, 04:46 PM
BBC69Camaro's Avatar
Default Fuel line interference?
Looking for a rear sway bar now that I am further along. I might be wrong but doesn't it look like the mount on the passenger's side frame rail might interfere with the stock fuel line routing? I have ran two 1/2 lines on the inside of the frame-rail (similar to stock routing just 2 1/2 lines).
Any close up pics of the framerail mounting, especially on the passengers?
Thanks!
Old 04-06-2009, 04:52 PM
Bakaruda's Avatar
Bakaruda Bakaruda is offline
Do you have these for Mopars?
Old 04-06-2009, 04:55 PM
Thanks!
Ditto
Old 04-06-2009, 05:49 PM
You only drill a 5/8 hole through the frame rail and tack a sleeve in the hole. You should be able to move your lines a bit to get out of the way.
Sorry I do not have a detail shot of the frame mounting, but here are a few we have installed
Frank Serafine
