Old 09-14-2008, 08:39 PM
awr68's Avatar
awr68 awr68 is offline
Originally Posted by Every Detail View Post
can i use coilovers with the air bar?and does anyone have any links to these web sites so I can check these other kits out.
Yes you can use coilovers with the air bar.
I would look into DSE, here's the link. They also have a mini-tub kit and sub-frame connectors for ya!!
http://www.detroitspeed.com/
Tony
'68 Camaro
Old 09-14-2008, 08:41 PM
awr68's Avatar
Originally Posted by frankenstang View Post
Hehe, have you seen this setup yet?
Is that a Schwartz chassis?
Tony
'68 Camaro
Old 09-14-2008, 11:10 PM
scherp69's Avatar
scherp69 scherp69 is offline
Here's the airbar with coilovers. Give Frank at www.gpsuperstore.com a call, he'll set you up.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 09-15-2008, 03:38 AM
holschen's Avatar
holschen holschen is offline
Default there maxg systems
http://www.maxgsystems.com/presenter...aspx?Id=104637
looks good but there´s to little info about this kit on this board??
camaro69-l92+6l80e-
speedtech(LCA)-ats Street-Comp AFX-unisteer r&p-VariShock
camaro 5gen rear
Hydratech Brake Booster
movit brakes 380mm 6piston front- brembo 465mm 4piston rear
275/30-19 front-325/25-20 rear
19x9f 20x12r cray scorpions
Old 09-15-2008, 06:09 AM
rich-allen's Avatar
rich-allen rich-allen is offline
Look over to your left, Max-G is a sponsor of this site
67 RS/SS
Old 09-15-2008, 07:21 AM
darren@ridetech's Avatar
darren@ridetech darren@ridetech is offline
Yes the AirBar will work with coil overs. 11.5" compressed and 16.5" extended
Old 09-15-2008, 09:04 AM
holschen's Avatar
Default yes i see now
but between the g-bar air-bar and max-g whats best for high speedperformance ??
still very little info about the max-g system
thanks eye up Rich
camaro69-l92+6l80e-
camaro 5gen rear
Old 09-15-2008, 11:16 AM
scherp69's Avatar
who makes that? But im not looking to spend that much.
I think that's what you need to figure out is what your budget is and how much you want to cut up your car.
Prodigy Bar, Air Bar or Alston G-bar (the air bar does not allow for any adjustment) all use coil overs and will bolt on to your existing frame rails. It's recommended that you weld in though. These will run you about $1800 to $2200 including coil over shocks. If you want something that is easy to install and has good performance (most people will not push their cars to the limits of these products) than these would be a good choice.
The DSE quadra link is a great product for about $2500. I know the first gen kit you had to cut your floor up, not sure if you do with this one. I'm leaning towards you would have to.
I don't much about the Lateral Dynamics except that it starts at about $3600 and goes from there depending on the options you choose.
Other than the Heidts one (which I don't know much about and have only heard that it's cheap), I think you start to get higher up into costs and quality (full chassis designs). Depending on what you are going to do with your car and how much you want to spend should help make your decision. I went with the air bar with coil overs (and will be getting Frank to upgrade the arms soon) as I know I will never push my car to the limit. I'm sure I'm going to be more than happy with the prodigy bar set up (once I get the upgraded arms).
Mike
New Gen Splitters
LS3 and TKO600
Old 09-15-2008, 11:57 AM
Marcus SC&C's Avatar
Marcus SC&C Marcus SC&C is offline
The coil over version of the AirBar is the G-Bar. It`s been out for several years now and has built a great reputation. It works great on the street and suprisingly well on the race track too. The "Prodigy Bar" is the Airbar with coilovers but with heims and adj. links. You can retrofit any G Bar with those for a few bucks with parts from any racing catalog. If the cars going to see a lot of street miles I wouldn`t. Heims transfer more NVH to the chassis and wear much faster than bushings. Our rule of thumb is that if it runs open headers then heims are fine. In a very clean environment they can hold up for a while but here in PA. we end up replacing even the most expensive heims every few years because they`re buzzing and rattling. We`ve got drawers full of them from client`s cars that we recycle on off road stuff where we don`t care if they rattle. There are 1st Gen Camaros outrunning new twin turbo,all wheel drive Nissan GT-Rs on the road race track with the standard G-Bar. You`ll see articles on it in the car rags in a couple months. Honestly I was suprised and I helped them set the Camaro up! My point is that it doesn`t necessarily have to be "upgraded" to perform well. I`d be very comfortable going for the G-Bar and never look back. I`ve been looking for a `78 TranAm to put one in myself. Here`s one of our clients cars with the G Bar.
The Max-G stuff is made by kit car company Highland Daytona Racing. They`re about 45 minutes from us. It`s race car stuff. If you`re building a race car and are sold on a satchell link then it might be worth checking out. Oddly for a race oriented piece it has no geometry adjustability. As many mufflers and I`ve smashed on my lowered 2nd Gens (8 of em) the height of that one crossmember makes me a little nervous. Mark SC&C
Old 09-15-2008, 04:02 PM
Below is The Prodigy Bar WITH the sway bar option at work on the Autocross and dragstrip. On the autocross we did good but as you can see I am no autocross driver and the car had a lot more in it. A real driver would have been right there with the better performances which were in the 37s for the most part except for a couple standouts that ran high 36s. I was slowing way to soon for the corners and babying it through the corners far to much. Being the straight liner I am you can see me get "comfortable" on the straights.
On the dragstrip, We lost the throttle cable half way through first gear, but you can see the thing hooks up pretty well with nearly 700 torque on the dragstrip and has no wheel hop even in a burnout with 100MPH wheel speed.
I have had the chance to use the car both with and without the conversion to the Rod Ends, and the car simply works better with the rod ends then with the urethane bushings. There is just no bind now, plain and simple.
I really do believe this is the best hooking suspension you can buy that handles too.
As Marcus mentioned, the Kevlar rod ends are absolutly for clean use in casual driven cars that are rode hard. They ARE NOT for everyday drivers. However, they are only $26 to replace, and take 5 minutes each to change. So for our cars that are drag or autocross on weekend, or just driven hard in good weather.
http://s169.photobucket.com/albums/u...t=MOV01020.flv
http://s169.photobucket.com/albums/u...t=MOV01029.flv
Frank Serafine
