Old 11-07-2008, 11:13 AM
The WidowMaker's Avatar
i went with the .82 version, but i have a 28.5" tire in the rear and 3.73's. i debated it for a while, but i determined that freeways around here are too slow to worry about cruising at 90. the .82 was perfect for a 75 mph cruise.
how tall is that 335? i think there is only one size 335, but i wasnt sure.
Tim
"The WidowMaker"
Old 11-07-2008, 01:18 PM
Flash68's Avatar
Flash68 Flash68 is offline
Tim
My 335 is 26.06" tall, so quite a bit shorter than yours.
And I have no problem cruising over 100+ in my area.
Yeah I am pretty set on going with the .64 now.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 11-07-2008, 08:52 PM
ChevyThunder's Avatar
ChevyThunder ChevyThunder is offline
Really? Why do u wish for .50? U like to cruise at 95mph on 280 or something?
All the time , and then some
Burn Rubber Not Your Soul
A bunch of Camaro's
Porsche 962
Porsche 935
Porsche IROC series RSR (Fittipaldi)
Old 11-08-2008, 01:28 AM
Flash68's Avatar
Yeah, I figure I will be doing some high speeds in my Camaro, but the REALLY high speeds will be seen in my 996TT.
2014 4 tap Keezer
Old 11-08-2008, 10:18 AM
bobhamilton15090 bobhamilton15090 is offline
I would go .64 that is what I did in my mustang w/ 3.73 gears and I run 2k rpm at 80 mph and 3k rpm at 100
Old 11-08-2008, 01:18 PM
Flash68's Avatar
Wow, I like those numbers. How tall is your rear tire Bob?
2014 4 tap Keezer
Old 11-08-2008, 07:34 PM
Blown353 Blown353 is offline
In order to spin 2K engine RPM at 80mph with 3.73 gears and a .64:1 OD, that requires a 32" tall tire.
However, with that same combination 100mph would be 2510rpm, so something doesn't add up.
1969 Chevelle
Old 11-08-2008, 09:08 PM
im running a 275/40/17 rear tire, my od gear is actually .63, but thats close enough to the topic for me!
Old 11-08-2008, 11:04 PM
Bob, a 275/40/17 tire is 25.7" diameter when new; so with your 3.73 rear gears and a .63:1 OD ratio (and also assuming there is no slip anywhere, and there shouldn't be with a stick) your RPM/MPH is as follows:
RPM / Speed
7000 RPM 228 MPH
6500 RPM 212 MPH
6000 RPM 195 MPH
5500 RPM 179 MPH
5000 RPM 163 MPH
4500 RPM 146 MPH
4000 RPM 130 MPH
3500 RPM 114 MPH
3000 RPM 97 MPH
2500 RPM 81 MPH
2000 RPM 65 MPH
1500 RPM 49 MPH
1000 RPM 33 MPH
So your 3000 rpm @ 100 mph observation is very close, but at 2K rpm you're going 65.
1969 Chevelle
Old 11-08-2008, 11:14 PM
Flash68's Avatar
RPM / Speed
7000 RPM 228 MPH
6500 RPM 212 MPH
6000 RPM 195 MPH
5500 RPM 179 MPH
5000 RPM 163 MPH
4500 RPM 146 MPH
4000 RPM 130 MPH
3500 RPM 114 MPH
3000 RPM 97 MPH
2500 RPM 81 MPH
2000 RPM 65 MPH
1500 RPM 49 MPH
1000 RPM 33 MPH
I look forward to hitting 7000rpm in 5th gear.
2014 4 tap Keezer
