Old 11-05-2008, 02:18 PM
Flash68's Avatar
Flash68 Flash68 is offline
Default .82 or .64 TKO?
Hey guys. I have to send back my TKO 600 to get the shifter location changed, so I have the opportunity to switch to the road race version with the .82 overdrive/5th gear. Wondering if I should do it. Here is my setup and welcome comments and suggestions.
68 Camaro
Currie 9" rear with 3.70 gears
TKO 600
Procharged 406 small block = 650-700rwhp
Air Bar 4 link
275 front/335 rear tires
Intended use: 95% street driving, maybe some road course or 1/4 mile for fun occasionally
Thoughts?
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 11-05-2008, 03:35 PM
Josh69 Josh69 is offline
Have you driven it yet as is to see what it behaves like in OD?
I have the TKO600 with the .64 and a 3.73 in a Moser 12 bolt with 25.5" tires. I would have gone with either the .82 or a 3.90/4.11 if I had it to do over. I'm around 1900rpms, and it wants to load up. I'm running a single plane and a quick fuel 750 race carb built for E85. I'm looking to supercharge mine as well, and have some of the same concerns. I imagine it'd be worse with the blower drag on it in my situation. I'm heading to the dyno room to try to sort it out. If not, I'll be dropping in some 4:11's.
My cam is a hydraulic flat tappet 236/242 @ .050, 108cl, .516/523 lift. I guess it really comes down to how your motor wants to run under load at 2K rpm's or less. Right now you'll be in the 1800-2000 range at 55-60. Fourth gear can be pretty annoying with a 3:70 at 60mph if you can't hit 5th. I drive 30 miles each way to my office on a 2 lane where it's hard to get past 60mph.....it sucks not using the OD in those situations.
1969 Firebird, Black w/Parchment Arizen interior, 383 Pontiac Stroker (350/428 crank), TKO600, Moser 12 bolt, 18" TTII's, Hotchkis, GW, DSE, Speed Tech, Vintage A/C, etc.
Old 11-05-2008, 05:56 PM
mazspeed's Avatar
mazspeed mazspeed is offline
.64. I wish I had a .50 in mine with a 3.73 gear set.
Old 11-05-2008, 06:35 PM
Flash68's Avatar
Car is not done so no I have not driven it yet. I shouldn't have loading up problems at low rpms since I have EFI. I failed to mention that I guess.
2014 4 tap Keezer
Old 11-05-2008, 06:37 PM
Flash68's Avatar
Really? Why do u wish for .50? U like to cruise at 95mph on 280 or something?
2014 4 tap Keezer
Old 11-05-2008, 06:57 PM
MtotheIKEo MtotheIKEo is offline
if it's going to be mostly a street car/cruiser I would go with a .64
Old 11-05-2008, 11:01 PM
Blown353 Blown353 is offline
Depends on the cam-- regardless of induction some cams just aren't happy being loaded under a certain RPM and the engine will surge and buck no matter what combination of timing and AFR you give it.
With 3.70 gears and that tire diameter, my preference to make it a freeway-friendly car would be the .64 gears unless the cam is really big. But knowing you have Don's old motor the .64 OD should be just fine, I seem to remember that cam "cleaning up" around 1600-1700 rpm from the few times I was in the car, so you should be able to shift into 5th around 50-55 mph and it will be happy.
Why are you having to send the TKO back to move the shifter? You can easily switch the shifter location yourself between the 16.25 and 19" location; you just unbolt it and rotate it 180. The only more complex shifter relocations are if you have the shifter located really forward under one of the midlength covers instead of on the tailhousing, that gets more involved and needs extra parts.
1969 Chevelle
Old 11-06-2008, 12:09 AM
Flash68's Avatar
Makes sense. I don't think is cam is really huge based on what I know.
That's a pretty low rpm so yeah that should be okay.
I am sending it back to Keisler cuz they have to modify the tailshaft or some part that apparently only they should do. I asked them it is more work than just switching that plate around. This will also allow me to run the Pro 5.0 shifter base that I want to run now, which I cannot in the tranny's current form. It's pretty cheap actually and they are just gonna switch this tranny out for a new unmodified one from Tremec where they have not messed with it yet except for the 19.25" shifter location (currently it is 16" - so, a 3.25" difference).
2014 4 tap Keezer
Old 11-06-2008, 12:14 AM
mazspeed's Avatar
I'm going a lot faster, trust me
You really do want the .64. It's a bigger jump from the 4th gear, but well worth it on the freeway. You won't be sorry.
Old 11-06-2008, 12:22 AM
Flash68's Avatar
I believe it. And I hope to join you soon!
Yeah I think the .64 is the one to stick with.
2014 4 tap Keezer
