Old 11-15-2008, 04:50 PM
James OLC's Avatar
The basic ISIS Intelligent Multiplex System (kit) includes all of the wiring that you will need for most installations. At this point you still have to build your own terminations at the loads but you could also go into your existing harness if you wanted to. Jay and the guys at ISIS are working on a couple of things to streamline the kit for musclecar and other applications.
With the optional InTOUCH unit you can indeed go with no auxiallary switches. In the OneLapCamaro that is the direction that we have gone.
I can not say enough good things about the ISIS System and the great support that the company has provided me during the installation. The flexibility and overall potential of the system honestly makes it second to none with respect aftermarket wiring solutions.
Just so there is full disclosure - I am sponsored by ISIS and am using it in the '67. I did install the entire system - myself - in about 20 hours (not counting fabricating brackets and panel mounts). I have had zero electrical issues with the car since it was 'finished' for SEMA and I will certainly use an ISIS kit on my next build.
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 11-16-2008, 09:54 AM
ISIS - KSTORZ ISIS - KSTORZ is offline
Originally Posted by zbugger View Post
I'm just wondering if you have to use your existing harness to wire into the unit, or if it comes with the necessary wiring to go from the box to the lights, etc.
Hi guys -
Just to clarify...The 3 box system (1 mastercell and 2 powercells) comes with wiring for 50 inputs (Mastercell), 20 outputs (10 per Powercell) and the can bus cables to connect everthing together.
If you have existing wires...you can connect them to the ISIS wires.
If you don't have wires...you can run the ISIS wires to the desired length to you output.
ISIS is just that flexible and makes wiring that easy.
Karl
Old 11-16-2008, 09:59 AM
DOOM's Avatar
DOOM DOOM is offline
I think im sold on this !!. Plus there in my back yard... Karl are you a dealer? You should get with Scott and get some space on this forum!!
Mario
Old 11-16-2008, 10:23 AM
zbugger's Avatar
zbugger zbugger is offline
Originally Posted by ISIS - KSTORZ View Post
Hi guys -
Karl
Well thank you very much for giving me another way to lose money. Now I REALLY want to run this.
Lost in a hopeless world on a path that wanders aimlessly and endlessly... As if it really even mattered.
Old 11-16-2008, 10:33 AM
awr68's Avatar
awr68 awr68 is offline
Guys I went by their booth at SEMA and I have to say this is a very trick setup! I got a pretty long demo on it and I have to say it sure looks like it would help wire a car faster, cleaner, and be able to diagnose any problems you might have.
Great product ISIS!!
Tony
'68 Camaro
Old 11-16-2008, 10:47 AM
BRIAN BRIAN is offline
Sounds like cool product but not sure if all that technology is needed on a basic Hot Rod?
Reading through some of the pages it notes that it shuts down if it gets too hot or if the battery goes low? Does it go into a limp home mode or are you dead in the water? Anybody ever have one shut down? How many systems out there running and driving with miles on them.
Old 11-16-2008, 04:20 PM
Mario
Hi Mario -
No I'm not a dealer...I actually work for Littelfuse...ISIS is a brand of Littelfuse.
Our demo units just returned on Friday from SEMA...if you would like to see ISIS up-close...let me know and I'll make myself available.
Old 11-16-2008, 04:47 PM
Hi Brian -
There are several options to address your concern if a problem occurs.
1. There is a limp home mode if a "major" problem were to occur.
2. ISIS has the capability to "Load Shed" if desired. As ISIS continuously monitors the battery, if the alternator were to fail and the battery started to loose power...ISIS can shed "Non-critical" functions (i.e radio, amps, etc) in order to get you home.
Hope this helps.
Karl
Old 11-16-2008, 04:50 PM
Hi Anthony
Thanks for visiting the ISIS booth @ SEMA.
Karl
Old 11-16-2008, 08:01 PM
skatinjay27's Avatar
Hi Brian -
Hope this helps.
Karl
man!!!! isis freaking awesome.
its like everytime there is a question/fear. its was already thought about and delt with.
I really cant seem to find one negative about it or advantage a traditional wiring harness has over it.
AJ
