Originally Posted by jcal87
Ok any recommendations on good suspension componets to throw on a stock subframe and ya the wheels and tires have to go for sure...thats just the way it was when i bought it but they will defenitly have to go.
If I were you (and I once was in your position) I'd spend a lot of time reading David Pozzi's site, and then search for Camaro suspension threads here and on Pro-touring.com.
The stock subframe can be made to handle extremely well; leaf springs in the rear also work extremely well. Too many people (I'm not suggesting you're one of them) spend money before planning out their car. Figure out how much you want to spend; figure out how you want to use your car (there's corner carving on the street and there's corner carving on a track); figure out how much you can do and how much you will have to farm out, and how important bling is as compared to a hard eyed focus on performance improvements. There's really nothing to point to under the hood with the Guldstrand mod, it just works.
The cheapest approach is delrin/delalum UCA/LCA bushings, the Guldstrand mod, good springs, shocks, swaybar and BRAKES. I've got this on my current '68 Camaro driver, and it's a great setup.
You can do a better correction of the front suspension with the SC&C tall balljoints in their UCAs. The "magic" though is in the balljoints, not the UCAs. A tubular UCA with a stock height ball joint is only going to give you "bling," not performance improvement. Tubular LCA's also don't correct geometry, but may help re-center your front wheel in the wheel well reducing or eliminating rub when you have an aggressive caster setting in your alignment. (The ATS tall spindle is a great choice also - similar approach as the tall ball joint with a number of other advantages - but may no longer be available.)
After that, though, I think you're looking at one of the "handling" subframes from DSE, AME or 21st Century Street Machine to name a few. However, plan on spending roughly $7,000 for any of these subs. I would not look at Heidt's, Martz, Fatman or any of the more hotrod oriented subframes if you really want to use your car hard in the twisties or at the track; nor would I go to Speedtech - which gives you the choice of the stock UCA mounting point and relies on something like the SC&C tall ball joint for geometry correction, or has the Guldstrand mod built in.
Read, search and then ask any questions you may still have. And don't forget good brakes.
