Old 02-10-2009, 09:09 AM
dwfastcam dwfastcam is offline
Originally Posted by jcal87 View Post
I am gonna tag along on this thread what is the correct size body mount bushing for a 68 camaro and where can i find the solid bushings because im pretty sure the bushings i have now are stock 1968 and there worn to hell.
DSE and Global West makes some nice ones. Im sure there are other companies that make them as well. Just a side note, because I have ran into this several times on the cars that I have built.
With worn out Body/subframe bushings, the body can tend to move to one side or another. causing tires to rub only on one fender well, this can cause several issues with tracking, etc.
When installing new bushings, be sure that the frame goes back in correctly. I know that on the first gen Camaro, there are small holes next to the body bolts in both the frame and lower fire-wall mount. You can stick bar in and line these up, also, using a point of reference from the frame and measuring it to reference point on both sides of the body, to make sure that it is square.
Hope this helps,
DW
Old 02-15-2009, 08:53 AM
RdHuggr68 RdHuggr68 is offline
DSE has solid bidy mounts, ask for their catalog, it is full of great stuff. Good Luck
Old 02-15-2009, 08:54 AM
DSE has solid body mounts, ask for their catalog, it is full of great stuff. Good Luck
Old 02-15-2009, 12:46 PM
awr68's Avatar
awr68 awr68 is offline
Speed Tech has them as well.
Tony
'68 Camaro
