Old 02-09-2009, 06:30 PM
RdHuggr68 RdHuggr68 is offline
Default Body Mounts
I just removed the body and found out the body mounts are solid aluminum mounts. a few people told me keep them,but I am wondering if I should replace them with polyurethane mounts. Anybody have any experience with these solid mounts?
Old 02-09-2009, 06:33 PM
Most of us are running solids. With subframe connectors it's a must.
Old 02-09-2009, 06:41 PM
awr68's Avatar
awr68 awr68 is offline
and use stock height!!
Tony
'68 Camaro
Old 02-09-2009, 07:36 PM
dwfastcam dwfastcam is offline
AWR68
Aside from tunnel clearance issues, what is the dis-advantage to running the 1/2 drop bushings?
Old 02-09-2009, 07:45 PM
jpdeuce's Avatar
jpdeuce jpdeuce is offline
Possible clearance issues with the transmission, clutch fork, scattershield, headers, and tranny crossmember. Can be a real PITA to use 1/2 height.
Old 02-09-2009, 08:00 PM
awr68's Avatar
That about covers it! Thanks!!
Personally I have had trans tunnel issues and the stock trans x-member wouldn't work with the stock sub-frame...so I used the ATS T56 x-member, on my old frame that is....
Tony
'68 Camaro
Old 02-09-2009, 09:15 PM
Don't forget air cleaner. I barely snuck by with the half height bushings. I had ATS build me a cross member and shimmed it to my desired driveline angle. It's how shall I say it...a smidge from the tunnel. One other thing I have found is that the engine is more sensitive to coolant level. To prevent an air pocket in the engine,you want your coolant level higher in the radiator. I didn't have any bellhousing, clutch fork, header, problems. If I would have planned to run half height busings then I would have cut the tunnel for more clearance. Other than that, it's really not that big a deal.
Old 02-09-2009, 09:24 PM
awr68's Avatar
I went ahead and raised my tunnel .75" everything fits fine now.
Tony
'68 Camaro
Old 02-10-2009, 01:51 AM
Awesome, thanks for the info guys!
Old 02-10-2009, 02:44 AM
jcal87's Avatar
jcal87 jcal87 is offline
I am gonna tag along on this thread what is the correct size body mount bushing for a 68 camaro and where can i find the solid bushings because im pretty sure the bushings i have now are stock 1968 and there worn to hell.
