Old 01-11-2005, 07:22 AM
68protouring454's Avatar
Default pic please
jim, we would love some pics of the martz set-up
jake
Old 01-11-2005, 09:47 AM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
I'm still cuttin and have to dig the Martz chassis 4 Link out of my other garage ( I am going to run it). I will lay it out with the Currie 9 inch and take pix, Cool?
Rick I will call you today. Thanks Jan for the input also and to the rest of you guys for the support. I really appreciate it.
Jim
Old 01-11-2005, 10:12 AM
Default pics
sounds good jim, does the kit look like it is assembled nice, ie welds, links etc?
also what was the cost of the kit?? 1,200??
rick any impressions on driving with the matrz other than no problems, had you driven your car with leafs before the martz rear?? or did you not get the car as a driver? rick, also any pics of build up and install pics of 4 link? thanks guys
jake
Old 01-11-2005, 12:35 PM
Ummgawa's Avatar
Yes the welds are super nice. The front perch (forlack of a better term) bolts to the front spring perch holes. You weld it up, place the jig in the front perch set up, do some measuring, spot weld the 4 link braces on, remove, and weld up. The biggie is the upper brace for the coil overs. It is different than the DSE piece in that it sets back farther and is strait across.
It was 1200.00 included the coil overs and the coil springs. All said and done, same than DSE mini tub.
Jim
Old 01-11-2005, 01:31 PM
Y-TRY Y-TRY is offline
Originally Posted by 3SuperSports
I've been thinking about buying that setup for my car. Any real reason not to?
I second that motion.
The thing about adjustable stuff is that it has to be adjusted. How hard is it to dial-in the 4-link?
Old 01-17-2005, 10:20 AM
Default pics
just a reminder jim for some pics when you get a chance.
jake
Old 01-17-2005, 10:26 AM
Ummgawa's Avatar
Jake, no problem. I am trying to finish my rendering, I have a daughter that has had a 3 day volleyball tournament and I am real busy. I will lay it out in the floor of my garage and take pix.
Jim
Old 01-17-2005, 11:07 AM
sinned's Avatar
sinned sinned is offline
Jan, what happens when you decide to change ride height for whatever reason.....if the PHB is fixed you are screwed.
It is also nice to be able to change roll center height once on the track to tune the rear end.
Dennis
Old 01-17-2005, 02:56 PM
Default busy
no prob jim, just saw the thread go to the 2nd page so i figured i would bring it back
jake
Old 01-20-2005, 02:54 PM
Ummgawa's Avatar
Jake
I emailed Scott some Pix of the set up. I had to find the box It came in. He's gonna make a new thread out of it. I just laid the parts out on my garage floor. They should be up tonight.
Jim
