Old 09-06-2009, 05:15 PM
camaro2nv's Avatar
camaro2nv camaro2nv is offline
OMG no good!
Old 09-06-2009, 08:53 PM
monza's Avatar
monza monza is offline
Damn didn't need that after every thing was coming together so nice.
Just have to remember, that's Hotrodding if it was easy everyone would have one.
Hope it comes together in a timely fashion!
Dave
FUeL 69 Camaro RS
68 Corvair coupe
65 Impala SS
65 Corvair convert
64 Corvair Rampside
62 Corvair Greenbrier
http://www.sourceboards.com/
Old 09-08-2009, 08:21 AM
Dang, we can read part numbers on that chunk detector !!!
Glad you caught it in the shop and not out on the track at full speed !!
Good luck this week and at the track. Jim
My Project: 65 Porsche 356G
https://lateral-g.net/forums/showthread.php4?t=5109
Old 09-08-2009, 09:06 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Originally Posted by David Pozzi View Post
Then no oil came out!
So where did all the gear oil go?
Old 09-08-2009, 09:11 AM
James OLC's Avatar
It was there - just on the other side of the plugged up drain hole... the shear volume of debris was pretty impressive.
Hopefully we get the third member off to Currie today and can get it turned around quickly. We'll be going with a True Trac and sticking with 3.89ish gears which should be perfect with the new Magnum transmission.
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 09-16-2009, 03:56 PM
James OLC's Avatar
Well the news right now is mostly good... Currie Enterprises was able to salvage our third member and replaced the blown up differential with a new True-Trac. It's in and David took it for it's first test drive yesterday. Indications are that we are good to go and with that being said...
We're Off!!!
As a test run for the One Lap of America in the spring I am going to try to maintain the OneLapCamaro Blog live through the Silver State Classic Challenge - there might be a glitch or two as we go but it should be interesting.
You can follow our progress "live" through the weekend on The OneLapCamaro Blog
Cheers!
(and you guys have fun at RTTH5!)
James
1969 Camaro - Dusty
Old 09-16-2009, 04:01 PM
ironworks's Avatar
Good lucK buddy.
Rodger
Old 09-16-2009, 07:07 PM
Steve1968LS2's Avatar
A six pack says you don't beat our .377 varience from last year.
Good luck with the run.. bet I will wish I was there instead of where I will be.
Old 09-17-2009, 11:27 AM
buickfunnycar.com's Avatar
Good luck James and great detective work Dave...
www.buickfunnycar.com
Old 09-17-2009, 12:13 PM
monza's Avatar
Good luck have fun!
Dave
FUeL 69 Camaro RS
68 Corvair coupe
65 Impala SS
65 Corvair convert
64 Corvair Rampside
