Old 08-25-2009, 11:09 PM
PASD U PASD U is offline
Wanting to learn something myself.
Old 08-25-2009, 11:44 PM
Flash68's Avatar
Flash68 Flash68 is offline
With the TKO I would go no higher (numerically) than 3.50 or 3.70. I switched my 3.89s out for 3.70 also due to the TKO. With that kind of power and the short 1st gear of the TKO, this is what I would do if I were you. One reason I wished I woulda done the T56 in hindsight, but oh well.
And since it's a street car I would do the .64 overdrive - same as I did and for the same reason.
Anthony's setup of T56 and 3.89 is an ideal setup to me.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 08-26-2009, 05:59 AM
XcYZ's Avatar
XcYZ XcYZ is offline
I'm pretty happy with my 3.70's, but I'm running a T56, so it's a bit different than the TKO600.
Since your BBC is going to make in the neighborhood of 600ft-lbs of torque, I'd lean towards gears in the 3.70 to 3.90 range with the size tires that you think you're going to run. I think that would be a great street setup.
My LS7 69 Camaro
Old 08-26-2009, 06:46 AM
Payton King's Avatar
Default Just something to think about
You need to figure what RPM you will be turning in your top gear at 65 mph. I can tell you from expirence that depending on your motor it could suck.
Although mine is completely different than yours, this is what I ran into.
I have 19s on the back with 285/30/19 I believe it is 27 tall. 3.80 gear and a T56. At 65 in 6th I was turning 1500 RPM. My car idles at 950. If anyone slowed me off of the 1500, my car would lug and I would have to shift into 5th. Big pain in the ass. Changed the gear to 4.11 and now in 6th at 65 mph I am turning 1750. Does not sound like that big of a deal but it is huge cruising on the interstate in traffic or trying to obey the law. I can slow to 55mph with out a down shift.
Old 08-26-2009, 07:38 AM
He's looking at a fairly radical camshaft so he will want to keep his overdrive in the 2000rpm range minimum with a big block chevy. Especially since it will be carbed. Mine is comfortable at 2k at around 60 mph. That makes it comfortable for most highway and all freeway jaunts. I agree with flash on the low 1st gear. I wouldn't want lower gears than a 3.73. I considered 3.55 gears but ultimately decided on 3.73 due to wanting to be in overdrive around 60 mph. The T56 is a whole different ballgame.
