Old 09-16-2009, 05:35 PM
Fluid Power's Avatar
Holy smokes Greg! I think you are being a little hard on the Wilton. The guy wanted home use and was looking at Craftsman for god sake. While the throat size is limited, I find that with the correct (good quality)blade for the job, along with using the right pulley selection given the material, it performs as expected. It works. Taking the time to set the machine up correctly gives me good results. Blade quality is paramount. Is it as good as a Dake or Doall? By no means. With that being said, for a home shop, it is better than Craftsman, and better than a porta-band. The issue with the combo vertical/horizontal saws is that while they work great as a drop saw, they make dangerous vertical saws. With minimal surface to use when cutting shapes, it is a trip to the hospital for sure. Just my opinion.
Darren
Old 09-16-2009, 06:33 PM
gtotto gtotto is offline
Originally Posted by XcYZ View Post
The Craftsman won't work for cutting metal, you just can't slow the blade speed down enough unless you're cutting very soft metals (brass, aluminum). Off the top of my head, I believe you want to be in the 100 ft/min range for cutting typical metal/steel. I had a Craftsman bandsaw and it just burned up the blade in seconds when trying to cut exhaust tubing. I bought a metal cutting bandsaw and what a difference, works awesome.
As another option, have you considered a handheld bandsaw? You can mount them to a portable table and work great.
I'm no expert but can't you find a 110volt "variable speed" adapter at an electrical supply house to slow the crafstman motor down?? Just a thought
Old 09-16-2009, 07:26 PM
Darren.... Too funny!
Yeah -- I'm kind of a tool snob.... and I hate low end tools to start with... so my "thoughts" on the Wilton might be a bit harsh - but I'd prefer to tell it like it is - and let the buyer beware... than to say "oh... it's a pretty good saw -- it's okay"... when it really isn't. It's home use - at best... and I think I was trying to see if he really needed a band saw... over getting something else that he might use more...
It's kind of like using a 'nibbler' for shaping a piece of sheet metal... yeah - it will work... yeah I have one... actually have a couple of them -- but I'd rather do almost anything else than use them. There are tools like that - that you can get a similar tool that does just as good of a job.. and might be more handy on a limited budget.
I agree on your thoughts on the Horz/Vert saws -- but if it were me -- I'd make up a piece to use as a table to give me more stability -- if that's what the saw needed. Again - I was thinking of a guy being on a budget - and trying to get a tool that can be used for various cuts.
Two tools in my "shed" that I wish I'd have done "better" - my mill/drill... and my vertical band saw. Both will be the first tools to be replaced. The Mill/Drill is a Jet --- and is actually a great drill press... but it's a lousy mill and just doesn't have to guts to really mill anything. Yeah - it works... and I can make it work... but I'd really like to have a "decent" milling machine... I'll keep it as a back up and a drill press...
You know my thoughts on the Wilton saw... I just should have bought a slightly larger - more HP version - more throat - and a more "precision" piece. LOL Having said that -- I've hot rodded this saw - with roller guides - killer blades - brushes on the rollers.
Old 09-16-2009, 07:56 PM
JRouche JRouche is offline
The craftsman has 80/150/200fpm speeds, perfect for all metals. JR
Old 09-16-2009, 08:11 PM
Hey, Im with you on decent tools. But sometimes the budget dictates the tool. I started out with crappy tools, then just above crappy then to some decent stuff intermingled with the crap.
For example, drill presses. Started with a hand held drill. Then a hand held in a holder wanna be drill press, then a nice lil ryobi 14" drill press, then a harbor freight 20" hunker that was powerful enough but the electrics were bad and the spindle was not too accurate. Then to my current clausing 20" with power down feed and variable speed.
Same thing with my lathes and mills. Now I have a decent southbed 10" for the long work, a really nice monarch 10" for the precision and a cnc for the contoured stuff. Two cnc mills and a sweet lil clausing horizontal.
And this is all home shop stuff cause well, thats where Im at, home
I would love to have a nice used dake, but I ran outta floor. Someone stole it all and if I catch them its ON!!!! Cant blame my wife for stealing the floor, she doesnt have anything in there. Someone did it though Errrr.... JR
Old 09-16-2009, 09:58 PM
Darren,
We've stole the thread here with our tool talk... Sorry to the originator! Really!
The one thing that affects everyone is "budget" - even guys with big budgets have to call it somewhere...
What I've tried to do - is to maximize the usefulness within a limited floor space... and that's what most home guys are trying to do - most likely in a 2 or 3 car garage.
I have to tell you -- as you already know -- that, is a tough thing to do! There are tools I'd just love to have - and are in my 'budget' - but aren't in the "maximize use / floor space" budget. With that in mind... that's what I was going for in the discussion on the bandsaw...
My shop is 1500 sq feet... many more times the average guys garage... and yes - many times smaller than some of them on here! I wish I had the space! But Urban living at it's finest precludes that... my wife just isn't into the smell of cows (Grin). I sure wish I had the knowledge/skill to run some of the stuff you have!! WOW!
Sitting here thinking about it - most of us are only going to build a couple of cars -- and tinker with a few more... we really are not going to wear these tools out any time soon. And since our TIME is actually FREE... if the saw takes a bit longer to cut some 1/4" aluminum plate... so what. I guess that's what separates 'us' from the 'pros'... we don't have the space... and we're not going to use the tools to the point of destruction. If I was going to make headers all day - I'd buy a killer band saw - and if I was building tube frames I'd have a $4K tube notcher... but as it is - I have to trace the tube and hand grind it on my Burr King... and finish it with the die grinder or angle grinder... But I can TIG weld it in place! Because that is a "tool" that I use all the time - for many things - large and small... multiple metals...
I was just thinking - I've actually used my variable speed jig saw - with bi metal blades - to cut more "scroll" type work than I have the band saw. And I can cut exhaust pipe with a $150 abrasive chop saw... or for that matter - I've used a sawzall for exhaust work as well as many other cuts.... But -- I can do that because I invested in a very nice vice to hold it... and a killer metal work table to clamp stuff to and to do layout work etc.
Old 09-17-2009, 06:42 AM
XcYZ's Avatar
XcYZ XcYZ is offline
The Craftsman free standing bandsaw I used didn't have those low blade speeds. That would have helped tremendously.
I have this Shop Fox unit, works great.
My LS7 69 Camaro
Old 09-17-2009, 04:39 PM
Nice saw Scott!!
Old 09-17-2009, 04:51 PM
Bryce Bryce is offline
i bought the Delta from sears and thorugh in a good aluminum blade. works great since most of my fab work is out of aluminum. But my idea for steel was to buy a new higher horsepower motor and build a gear reduction or just buy a variable speed motor to slow it down.
Old 09-17-2009, 07:59 PM
Thats the same saw I have cept under a diff name. They are all from china and a common model number is UE-712. Great saw!!!! I use some good but messy oil based coolant and a Morse blade. It cut stainless and steel with ease. Set it and forget it, walk away and listen for the clank when the cutouff hits the floor. I havent used it vertically yet. I use my bosch jig saw and bi-metal blades or my plasma for shape type cuts. JR
