Old 01-23-2010, 06:48 AM
HOLOHAN'S HOT ROD SHOP's Avatar
HOLOHAN'S HOT ROD SHOP HOLOHAN'S HOT ROD SHOP is offline
It can be done. You will have to use a mixture of 2 and 3" dia. roloc discs, 50 grit and brown scotch brite disc's- 80 grit cartridge rolls - 3/8 " wide belt sander with 80 git belts and scotch brite belts- 3" d/a with 80 grit hook-it discs and some final hand sanding. The key is to use Aluminum Tap Magic cutting fluid. Just a little goes a long way. Cuts down sanding time and build up of material on the discs. It's messy but well worth it.
Old 01-23-2010, 07:17 PM
CreepinDeth's Avatar
CreepinDeth CreepinDeth is offline
Chrome don't get ya home.....
I'd powdercoat it. That's what I'm doing to my Rocket 350's.
Old 01-29-2010, 02:11 PM
rallye455 rallye455 is offline
I started on it. Thuis is where I'm at so far.
Old 01-29-2010, 04:11 PM
Northeast Rod Run's Avatar
Northeast Rod Run Northeast Rod Run is offline
there's no turning back now. another 40 hours and you might be getting close
TJ Ragucci
http://www.northeastrodrun.com/
