Old 01-22-2010, 12:51 PM
rallye455 rallye455 is offline
Default Whats the best way to get an Edelbrock aluminum intake smooth to polish it?
Whats the best way to get an Edelbrock aluminum intake smooth enough to polish it?
Old 01-22-2010, 03:03 PM
marks914's Avatar
marks914 marks914 is offline
Regular User
Oh man, thats going to be a ton of work, start sanding and polishing. You could just get an endurashine intake, sell the old one to help the cost. here is my endurashine intake. its kind of chromy but very easy to clean, wish I would have gotten endurashine heads too
Mark
www.newvintageusa.com
Old 01-22-2010, 06:21 PM
732ndgen 732ndgen is offline
Arrow
i was thinking of powder coating mine with some other parts. not shur if that is a ggd idea or not.
Old 01-22-2010, 06:39 PM
mexMan's Avatar
mexMan mexMan is offline
I'd rather polish it than powder it, unless you're engine bay is too shiny or you have blacked out parts or matte finished block and head covers, but I'd rather polish it, and first you'd have to sand it with the 600 sandpaper... it might be a hell of a work, but at the end it might look awesome and clean.
''Every car has a great quality, is not the hands that build it, is the dedication behind it.''
Old 01-22-2010, 06:41 PM
Northeast Rod Run's Avatar
Northeast Rod Run Northeast Rod Run is offline
That's a ton of work. if you try polishing just one, you will see how much of a deal it is to buy them already polished.
for the average guy, I think it's best to start off with sandpaper rolls (or whatever they're called) on an air grinder and the heavier grit scotchbrite discs. A huge help when using the sandpaper rolls is to load them up with "grinder's grease". it's amazing how much that stuff helps. besides that a dremel and lots of sore fingers will do the job. I usually will work my way up to about a 1200 or 1600 grit paper before I start hitting the parts with Tripoli and White Roughe compounds for the final finish
I've polished a lot of rough parts (intakes, beat up half-shafts, cast waterpumps, rear trailing arms, rims, etc), and the worst thing I ever had to do was a dual quad tunnel ram intake. I'll never touch one of those again
TJ Ragucci
http://www.northeastrodrun.com/
Old 01-22-2010, 08:56 PM
chr2002ca's Avatar
I'd have to agree with the others. It's a ton of work no matter how you tackle it. Then, you have to keep on polishing it for the rest of its life unless you clear coat it. I would just sell it and buy one with the endurashine finish which will clean much easier over its lifetime.
Chris Robinson
Old 01-22-2010, 09:21 PM
What about blasting it with some material?? Then spraying it with a product that looks like polished aluminum or chrome? How's that for vague.....LOL I'd take the easy way out.
Old 01-22-2010, 09:25 PM
70rs's Avatar
70rs 70rs is offline
The ol "rattle shine" trick? Chrome in a can? Rattle can resto? Super idea! Hell of a lot easier than wearing your fingers down to the bones trying to polish it every other day.
Eric
Old 01-22-2010, 10:04 PM
PDX503 PDX503 is offline
Smile
Whats the best way to get an Edelbrock aluminum intake smooth enough to polish it? Pay someone...LOL
Old 01-22-2010, 10:23 PM
I'd send it to MexMan!
Seriously -- Aluminum "loads" up sand paper and grinding wheels and carbide tools etc -- so if you're really "bent" on doing this - do a bit of research on the RIGHT kind of paper etc to use. There are special grit types to cut aluminum.
You ask a simple question - but it's not one with a simple answer - because you don't mention if you have any tools - air die grinders or electric die grinders... and you're going to need some "long reach" tools/heads etc because you've got hard to reach places...
If you're like some people we know <------- "we" like to "invest" in tools and equipment that we intend to use forever... If you don't have the tools already - you're going to spend more on them than the manifold would cost... so only you can answer that question. Don't forget that you have to start with roughing grits - work your way down to the finer grits - and THEN you have to polish - so you're going to need various polishing attachments - cones - and balls - and buffs and compounds etc....
Just sayin' ----- you're tackling a big job if you're not already set up for it.
