Old 01-29-2010, 11:04 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Originally Posted by BBC71Nova View Post
That is awesome.
That MPG info is killer. I keep telling myself...keep the faith, the BBC is still the way to go
John
My best so far is 24mpg hiway, but I'm sure I could get better if I tried. lol On my trip home from Detroit last June, I made 660 miles in 10 hours (yes, I was really pushing), I averaged 22mpg, and that includes going through all the toll roads and construction in Chicago and stopping for gas twice.
Originally Posted by Neil B View Post
Another plug for Mike. He did a great job on my Procharged Corvette. I went in with a race gas tune from another tuner and left with a pump gas tune and improved driveability with virtually no loss of horsepower.
I also recommend buying HP Tuners and either going to the Precision Motorsports school or getting their learn at home kit. Tuning is fun and can easily be learned by enthusiasts.
I've never had Mike work on my car, but I've talked to him in person and he really knows his stuff.
My LS7 69 Camaro
Old 01-29-2010, 07:45 PM
Chicken Louie's Avatar
Chicken Louie Chicken Louie is offline
Originally Posted by KPC67 View Post
It's a long ways away but I have been wondering who I will get to help me with this up in Canada when the time comes...
KPC 67,
James Hatfield at HorsePower Solutions in Edmonton is a name I have heard a few times up here in Alberta.
Dave
Old 01-29-2010, 08:43 PM
KPC67's Avatar
KPC67 KPC67 is offline
Originally Posted by Chicken Louie View Post
KPC 67,
Dave
I will look into him.. thanks
Kevin Carter
Old 02-03-2010, 05:34 PM
BillyBobL71's Avatar
BillyBobL71 BillyBobL71 is offline
Default Awesome Results
Matt,
That is one fine Dyno sheet. Am changing my LS2 for an LS7, and would be elated to achieve the same results. Can you tell us what ALL you have done to your motor? And what gears are you running?
Thanks,
Billy Bob
Old 02-03-2010, 07:26 PM
MattG's Avatar
MattG MattG is offline
Originally Posted by BillyBobL71 View Post
Matt,
Thanks,
Billy Bob
Sure Billy,
It is really just the 430 LS7 that LME from Houston offers. LS7 block and heads (heads have mild exhaust work). Eagle crank with forged pistons, 11.5 to 1 compression. The intake manifold and throttle body were ported and I chose the Katech Torquer cam for the LS7. It is a wet sump motor with a 24 tooth crank and the harness is from Speartech set up with electronic throttle body and cruise control.
I chose the torquer cam because the car is 98% street driven and I wanted more torque (as you can see it worked). The final detail is the PowrMax 100mm MAF sensor that actually added almost 15 rwhp after changing it from the old Corvette 85mm MAF.
The tranny is a reworked T56 from a camaro that can handle 800ft/lbs and the rearend is a Ford 9 inch with 3:70 gears.
Lastly the exhaust is 1 7/8 primary longtubes from Lemons built specifically for the DSE subframe, and the go into 3 inch exhaust with x pipe and Magnaflow mufflers.
All of these parts work well together and the car has tons of power throughout the rpm range, but none of it matters without a good tune and once again, Ed from VA Speed really sorted it out for me!
Hope this helps,
Matt
'69 Camaro Coupe, Full Ridetech stage 3 suspension, moser wavetrac 12bolt, Forgelines, Ls3 Heads/Cam,T56 Magnum. Built by me and tuned by Ed!
'69 'Vert Camaro: DSE Sub-Frame, DSE Mini-Tub, DSE Four-Link w/9inch. LME LS7 427, T56. Tuned by Ed Hutchings, :SOLD!
Old 02-03-2010, 07:39 PM
James OLC's Avatar
Davenport in Calgary should be able to help you out - they seem to have one of the best handles on LS engines that I know of in "the neighborhood". Good luck
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 02-03-2010, 08:23 PM
Default Good Combination
Originally Posted by MattG View Post
Sure Billy,
Hope this helps,
Matt
Matt,
As they say "It's all in the details" and looks like your engine has all the good stuff to make that incredible torque curve. I'll be starting with a crate LS7, and have most of what you have, but your CR, head and intake work, and I suppose the 3 extra cubes, really took it over the top. I can only hope to get close to your specs with the right cam and extras. Talking strategy with Mike Norris tommorow. We'll see what he can pull out of his hat.
I asked about your final ratio as I've been driving my 69 LS2/T56 with 4:10s and although 5th and 6th are ok, 1st gear is absolutely worthless. Been thinking lower gears, but don't know which numbers to choose.
Billy Bob
