Old 02-12-2010, 09:01 AM
JayR JayR is offline
Lateral-G Supporting Vendor
Like Frank said, winding up a 20x15 to 220 will take some serious steam and your traction advantage will go out the window when your poor motor is trying to turn all that weight and mass at high MPH. Even the Veyron takes a super slippery car with traction control, AWD and 1000 hp to barely make 200 in a standing mile. A 12" wheel will work far better for top speed runs and will probably only require a wider rearend.
Old 02-12-2010, 01:26 PM
tyoneal's Avatar
tyoneal tyoneal is offline
You might want to contact the S.C.T.A. (Southern California Timing Association)
They are the people who run "Speed Week" at the Bonneville Salt Flats. They will certainly know who makes high speed tires and wheels.
Click on all the links that are associated with them, they are cool and very informative.
I wouldn't skimp on your research for this if 220 mph is in fact you goal.
Good Luck.
Keep us posted.
Ty
Project, "EnGULFed"
1964 Gulf Liveried, Corvette, "Grand Sport"
Ty O'Neal
"She Devil" aka. Betty
1969/70 Camaro SS
427 LS3, 600
Keisler Road and Track T-56
Full size 3 link and custom roll cage
315mm tires on rear, should fit the same on front. Worked to design a more effective shape.
"Chester's '65"
1965 Buick Riviera
Aiming for true PT Status with
the best available from the 70's and 80's
Old 02-18-2010, 11:11 AM
deuce_454's Avatar
Originally Posted by Junkie View Post
Picking up my new 69 Camaro at the end of this month, id to get a set of custom wheels made in either 18/19, or 19/20 could even go with a set of 18/18 if its my only option. The issue is i need a tire that can go on a 15 or 16" wide rear wheel that wont look terrible and is speed rated for over 200mph. Ive noticed most "street" tires only go to 345, the Veyron has a set of 365's but i need something even wider then that. Tire choices will really be the deciding factor on what size wheels i go with. Trying to run 210-220mph in the car.
are you sure you will hit 220 in the standing mile with an f2 blower? you will propably need the first 1000 horses just maintaining that speed... and the time you have to accelerate not an awefull lot when you are running that high a speed.. remember to accelerate to twice the speed on the same distance, you need eight times the horsepower (to the ground) NOT counting drag....
Jake: Hit it.
Old 02-18-2010, 03:08 PM
Drag has a lot to do with it (almost everything), but an F2 blower is more then capable of pushing a car past 220mph in one mile. They are good for 1600 plus horsepower... Since I have one, I have to stick up for them.
