Old 02-08-2010, 09:04 PM
Junkie Junkie is offline
Default high speed rated tires for a prostreet
Picking up my new 69 Camaro at the end of this month, id to get a set of custom wheels made in either 18/19, or 19/20 could even go with a set of 18/18 if its my only option. The issue is i need a tire that can go on a 15 or 16" wide rear wheel that wont look terrible and is speed rated for over 200mph. Ive noticed most "street" tires only go to 345, the Veyron has a set of 365's but i need something even wider then that. Tire choices will really be the deciding factor on what size wheels i go with. Trying to run 210-220mph in the car.
1970 C10, 1000hp street truck
2014 Viper, 800hp toy
1937 Ford, 500hp hot rod
1997 Supra, 1800hp race car
Old 02-08-2010, 09:11 PM
GMracer's Avatar
GMracer GMracer is offline
There is your width, I have them on my 20x15s. But only rated at 130.
Nick Schiffer
2001 Silverado Regular Cab Short Bed
Currently Under the Knife
Special Thanks to:
Air Ride Technologies - Wilwood Engineering
Old 02-08-2010, 09:12 PM
exactly, ive seen those on MT's website but i need something that is safe at 200+
Also are there any Aero mods to create some down force up front?
Old 02-08-2010, 09:35 PM
TwinSting's Avatar
TwinSting TwinSting is offline
There is no tire the size you are looking for that has the Z speed rating.
Old 02-09-2010, 09:23 PM
rocketman's Avatar
a drag slick.. why does it need to be z or y rated
Old 02-09-2010, 11:06 PM
MtotheIKEo MtotheIKEo is offline
You're only going to find a drag specific tire in that width, no road car uses a tire that wide.
Old 02-09-2010, 11:20 PM
Because im going to try to go well over 200mph in the car. Im concerned with the heat those runs build up on a drag tire. Would you wanna run for an entire mile at full throttle on a drag radial or slick?
Old 02-10-2010, 11:08 AM
A lot of Texas Mile cars use R6's of some other DOT-R tire like that, but again, you're only going to find them in normal road car sizes.
Old 02-10-2010, 04:38 PM
Put more narrow tires on it for the mile. 345/35/18 is the only drag radial I know of that can do that. Viper Guys use them all the time.
Those wide tires will be anchors in the mile anyway.
Frank Serafine
Old 02-10-2010, 05:32 PM
Thats what im thinking. Run a really wide "street" tire and then have a set of dedicated tires for the mile
