Old 02-23-2010, 06:14 PM
Blown353 Blown353 is offline
Originally Posted by TheKingOTW View Post
To pull excess heat out from under the hood. I machined the stock hood louvers between the ribs to open them up. It drops under hood temps by as much as 30-40 degrees and engine temp by 5-10 degrees.
I'm taking note of this idea.
Do you have the fan sucking hot air out of the engine compartment or blowing cool air in? Can't tell if it's a puller or pusher fan in the pics.
Also, I'd like to see some pics of how you reworked the hood internal bracing around the other vents you added.
1969 Chevelle
Old 02-25-2010, 12:49 PM
TheKingOTW TheKingOTW is offline
The fan sucks the hot air out through the stock hood ornaments that I machined. I will try and take some pics for you to see.
Old 02-25-2010, 01:03 PM
Just had the car on the Dyno. After making some A/F adjustments, the car picked up about 70HP, making 1085HP.
Old 02-25-2010, 05:42 PM
Sti_Guy's Avatar
Sti_Guy Sti_Guy is offline
Thats some nice gains almost 10% what fuel is your base?
Old 02-28-2010, 07:33 AM
93 Octane Pump Gas.
