Old 02-21-2010, 09:25 PM
MizfitJon MizfitJon is offline
a scanner to check the fuel trims while acting up would be best! Vacumn leak would probably show up at idle also though. Surge in idle or fords like to shutter almost take off at idle while your on the brake with a vacumn leak. I bet its plugs though. Is there a slight delay while cruising and you load it up with heavy throttle? I would just pull the plugs and check them first, bet thats where you will find your issue
Old 02-21-2010, 09:27 PM
oh...forgot to read the plugs were new! What brand? Hopefully motorcraft? If there some garage like bosch or something might as well throw them away! If they are motorcraft, check gap
Old 02-21-2010, 09:30 PM
Jr's Avatar
Jr Jr is offline
Yes, they are motorcraft.
Old 02-22-2010, 08:10 AM
Hydratech®'s Avatar
Hydratech® Hydratech® is offline
Supporting Manufacturer
HydratechBraking.com
If I recall correctly, this vintage of Mustang is MAF equipped (mass air flow). Air filters simply do not catch 100% = I'll bet you that the MAF sensor is dirty, which will cause drivability issues without necessarily setting codes (even highly experienced ASE Master Techs / Advanced Drivability Specialists miss this one). There should be two anti-tamper Torx screws holding the actual sensor (black plastic rectangular item) down to the MAF assembly casting. Remove the actual sensor and look for a tiny hotwire spot welded to 2 thicker pegs. Any dust, dirt, fuzz (and I mean magnifying glass visible) on the actual hot wire will insulate it from reading the appropriate amount of actual airflow entering the engine. The PCM adds fuel based upon the amount of air entering into the engine, and will skew the fuel tables to the lean side if it is reading low amounts of air to the PCM. Having said all of this, I advise you respect how delicate this sensor is. One wrong move and you will wreck it and they are not cheap to replace. This is also applicable to most all hotwire type MAF cars (there is also a siphon type design that is less sensitive to dirt) - you would be suprised how much better a vehicle can run when the MAF sensor is cleaned (providing it was dirty).
Hey wait a second, aren't you the hydroboost guy?? LOL
There IS a difference - Thank you for choosing Hydratech!
Paul M. Clark <-- the Ukrainian - Slava Ukraini !
Founder / Master Engineer
Hydratech Braking Systems ®
www.hydratechbraking.com
Old 02-22-2010, 11:04 AM
Jr's Avatar
Jr Jr is offline
Paul,
I give take a look at it when she gets home.
Old 02-22-2010, 01:39 PM
70rs's Avatar
70rs 70rs is offline
that is some great info Paul. Thanks for posting it. I will keep it in mind for any future issues I may run into.
Eric
Old 02-22-2010, 02:11 PM
novanutcase's Avatar
My '03 'Stang is having some idling issues so I'm gonna give the MAF a blast of electrical cleaner and see if it fixes the problem.
John
Old 02-22-2010, 09:05 PM
thats why being able to see the fuel trims would help out to diagnose this problem.......
Old 02-22-2010, 11:30 PM
1962nova's Avatar
1962nova 1962nova is offline
Originally Posted by DJW32 View Post
Hey guys,
What would cause a 2002 ford mustang to sputter at 60-65 MPH? The wife's car just started doing this weird sputter on the freeway. What's funny, the RPM to don't fluctuate, the speed of the car stays the same, and power stays on the whole time the car is in motion. This is weird.
Breakdown of the car:
Ford
Mustang
auto
3.6 or 3.8 V6
everything is stock on this car.
We would appreciate any help on the subject.
Just buy your wife a new car....
1962 Nova 2-door post. TCI IFS/4-link, 9" w/3.70, 383 w/ 579hp, 2004R......Almost done.
Old 02-24-2010, 11:22 AM
Jr's Avatar
Jr Jr is offline
Take it easy on throwing the rocks...I have seen your glass house.
