Old 02-21-2010, 09:33 AM
Jr's Avatar
Jr Jr is offline
Default Sputtering problem with 2002 mustang
Hey guys,
What would cause a 2002 ford mustang to sputter at 60-65 MPH? The wife's car just started doing this weird sputter on the freeway. What's funny, the RPM to don't fluctuate, the speed of the car stays the same, and power stays on the whole time the car is in motion. This is weird.
Breakdown of the car:
Ford
Mustang
auto
3.6 or 3.8 V6
everything is stock on this car.
We would appreciate any help on the subject.
Old 02-21-2010, 09:37 AM
70rs's Avatar
70rs 70rs is offline
How many miles are on it? MAYBE a sign of the fuel filter getting plugged up? I have my doubts about that though as you should feel a reduction in power if it was getting fuel starved. Check the basics first, plugs, filters, any loose vac lines, electrical connections...
Eric
Old 02-21-2010, 12:52 PM
Jr's Avatar
Jr Jr is offline
I forgot to mention that the spark plugs, fuel pump and, fuel filter are brand new. Also, I checked the plug wires to make sure there is a connection. I will need to check the vac lines. Could this be a vac line? everything works fine until you get to 55-65...
Old 02-21-2010, 01:09 PM
70rs's Avatar
If all of those items are new then I am lost. Unless the trouble started at the same time the tune up was done?
There is a chance it could be a vac line, but honestly I doubt it is. Do you have a scanner to check trouble codes with? That will get you right to the source of the problem. If you don't have one, maybe a shop near you will scan it for a small charge and then you can take care of the problem at home.
You are sure it is the engine you are feeling and not the transmission acting funny?
Eric
Old 02-21-2010, 01:27 PM
BlackenedRR's Avatar
BlackenedRR BlackenedRR is offline
Look on the steering wheel, the problem is circled for ya! LOL!!!!! But really, I think Autozone does free code scanning still, might be a good place to start as stated above.
Jeff K.
'96 Chevy CCSB 1/2-ton Centurion Conversion
'95 GMC Reg Cab Shortie
Old 02-21-2010, 01:30 PM
70rs's Avatar
You found the problem!! Nice work!
Eric
Old 02-21-2010, 09:25 PM
Jr's Avatar
Jr Jr is offline
Very funny. I didn't pick the car.
Old 02-21-2010, 09:46 PM
70rs's Avatar
Just teasing. I actually just sold a 2000 GT Mustang a couple years ago. It was my wifes daily driver for a long time. I never had the same trouble you are and I wish I knew which direction to send you in. I think a scan at this time is your best bet.
Eric
Old 02-21-2010, 09:55 PM
Jr's Avatar
Jr Jr is offline
Yeah, I think that is the next step.
Old 02-21-2010, 09:59 PM
You might also check for any Ford tech bulletins on this issue, just a thought.
Jeff K.
