Old 03-31-2010, 04:56 PM
70rs's Avatar
70rs 70rs is offline
Originally Posted by monza View Post
Kinsler IR intake I think you mean, ya that thing is sexy!! Something like that, they won't fit. (I'll double check)
I'll also need to address how air comes in and exits the engine compartment, like you mentioned.
Bingo! The Kinsler unit. Very nice!!
Where do the air intakes drop down to right now? If you remove those can you replace them with a fabricated "scoop" to get air from the same areas and just flood the engine compartment with good cool air?
Eric
Old 04-01-2010, 05:07 AM
legend legend is offline
itbs with properly designed airbox and a big enough feed pipe will be superior to open filters in the engine bay
look closely at the McLaren F1 engine above
those surface area calcs are bunk, remember that one cylinder will breathe at a time, so the surface area of the single throttle plate is fine, ITBs work by allowing pulse tuning/ tuned lengths. however with a 90 degree v8 the pulse tuning doesn't work as well as something like a ferrari v8 with a flat crank
Old 04-01-2010, 08:04 AM
monza's Avatar
monza monza is offline
I don't really know which direction to go, back and forth. The old set up worked so I'm thinking (with my wallet) maybe fix the box?
I don't know?
Dave
FUeL 69 Camaro RS
68 Corvair coupe
65 Impala SS
65 Corvair convert
64 Corvair Rampside
62 Corvair Greenbrier
http://www.sourceboards.com/
Old 04-01-2010, 11:08 AM
JamesJ JamesJ is offline
I don't know?
Bingo ! Just fix what you got, is the crack on the top, if yes maybe switch the box to teh other side and then it is on the bottom, you wont even be able to see it.
James J.
Old 04-01-2010, 07:56 PM
monza's Avatar
Good idea, thanks. Harrop did locate me a set if I need it (them- need to buy the set). Still doing research on the cold intake vs. the stacks (trumpets) Seems to be lots of varied theories.
Legend thanks Maclaren I'm sure did the research, sick looking engine!
Dave
FUeL 69 Camaro RS
68 Corvair coupe
65 Impala SS
65 Corvair convert
64 Corvair Rampside
Old 04-10-2010, 01:21 PM
70rs's Avatar
Dave,
Did you make any decisions on the intake yet?
Eric
Old 09-18-2013, 01:42 PM
monza's Avatar
I did here you go: (sorry three year late reply...my kids- 3 and 5 and work took over priorities for a while, I'm back working/playing with FuEL)
I cut the existing boxes up and rebuild them bigger and way stronger the 3" has gone to 4" on both sides and 2" fatter through out every where else. Now to just make some 4" tubes running to air filters in similar location as the old air filter intakes...
Slowly tweaking other things as well.
Dave
FUeL 69 Camaro RS
68 Corvair coupe
65 Impala SS
65 Corvair convert
64 Corvair Rampside
Last edited by monza; 09-18-2013 at 01:43 PM. Reason: sorry for bad pics and rotated pics??
Old 09-18-2013, 01:51 PM
monza's Avatar
I noticed this on a Ferrari and how they reduce air intake turbulence, the red extensions do nothing except mellow out the air flow. Sorry for the Ferrari pic but I thought it was interesting.
Dave
FUeL 69 Camaro RS
68 Corvair coupe
65 Impala SS
65 Corvair convert
64 Corvair Rampside
