Old 10-13-2010, 09:29 AM
funcars funcars is offline
Default Sliding joint for torque arm front
I need to decide how best to allow the front of a torque arm to move in and out in very tight space constraints. A double rod end link would work but it needs more vertical space than a telescoping link with a large rod end at the end. A single rod end (or urethane end) will be in bending but at the end of the torque arm the loads are very low.
My main issue is deciding how to do a telescoping link. I've seen some versions on the market, but I want to fab my own. I can use teflon or other bearing materials. Has anyone done there own and used this type of design?
The car is a 70 mach I with a dry sump motor, my own front end (stock car type LCA, new frame channels, Pro coilovers, splined sway bar, etc.) and fullfloater in the rear. I am going to switch to a cambered rear once the torque arm is in. The torque arm is partially fabbed already and will mount on the pass side of the tunnel down low (it's tight).
Thanks for any input.
1970 Mach I 380 Dry Sump + lots of mods
1990 C4 Corvette 400 in solid roller
1965 Corvette - back to life some day
1970 1/2 Z28 project car
Old 10-13-2010, 10:20 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
i don't know how well they handle side loads but could you modify a set of slide-a-links? or build something off the design? it would give you your up and down movement, roll movement and your in and out movement.
Old 10-13-2010, 10:53 AM
exwestracer's Avatar
exwestracer exwestracer is offline
You don't really need a sliding torque arm. Yes, it would save a little space, but you are inviting wear and bind issues under acceleration and braking (and yes, I know they are built and sold that way). I've engineered and built a number of street torque arm setups, and along the way I've found a little piece that solves most space constraint problems.
This is a toe control link from a early 90s BMW 750 sedan. It's basically 2 spherical bearings built into a forged "dog bone" housing. To give you an idea of the size, those are 14mm (9/16) bolts going through it. The whole thing is about 2 1/2" long, far shorter than you could get with a M/F rod end setup. They are still available as replacement parts.
If I'm on a project where there is a real space issue, I build the front end of the torque arm with an upward jog so the bottom hole of the dog bone is level with the bottom of the arm. Since the dog bone has freedom to move in all planes, it will try to fold over under braking, so you'd need a small lateral locating link between the arm and the chassis.
If you are committed to the sliding end idea, QA1 makes a 3/4 X 7/8 shank rod end (p/n RMX1214) that is about 50% stronger in bending strength than the standard 3/4 end. I would get a 6" long piece of 1 1/4" machinable bronze round stock, drill and tap it for the 7/8" rod end, and slide it all the way into a piece of 1 1/2X.120 wall DOM or 4130 tubing, which would be the forward end of your torque arm. Use a jam nut and thread the rod end in completely.
Hope this helps.
Ray Kaufman-Wyotech chassis fab instructor
Custom suspension design and consultation.
(Now 2) Big Block asphalt supermodified ('cause too much is never enough...)
Old 10-13-2010, 02:42 PM
Thanks for the ideas. I have a 91 M5 with a similiar part and understand what you are getting at. I have also seen dogbones with two spherical bearings which is similiar in concept as well. I was not entirely clear on what you meant by needing another lateral locating link though. Do you mean that the torque arm could move sideways and down instead of purely front to rear (a twisting motion)?
Thanks again
Old 10-13-2010, 08:30 PM
Thanks again
Exactly. There is nothing preventing it from "folding" over to the limit of the spehricals when you hit the brakes.
Old 10-15-2010, 04:48 AM
ProTouring442's Avatar
Thanks for the ideas. I have a 91 M5 with a similar part and understand what you are getting at.
An M5 eh? Nice! I have a '93 M5 in Calypso Red.
I'm confused here... why would braking exert a force on the arm other than a downward motion? Obviously there will be twisting of the arm depending on the individual height of the rear wheels, but for the arm to flop over, wouldn't the axle need to be radically off kilter?
Shiny Side Up!
Bill
Old 10-15-2010, 09:56 PM
Shiny Side Up!
Bill
You're right, braking force is directly the opposite of acceleration, but it's a LOT of force, and with spherical bearings, there is nothing holding them in alignment with the "dog bone". Take 2 big ball bearings, set them one on top of the other, and press down really hard. They will shoot out to the side. Same sort of deal.
Old 10-16-2010, 05:23 AM
Ah! Got it! Thanks!!
Shiny Side Up!
Bill
