Old 11-04-2010, 01:03 PM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
Originally Posted by pokey64 View Post
I took it as just buy a camaro with a V8 in it already.
I agree
Scott from NJ
Old 11-04-2010, 01:10 PM
chrismx4's Avatar
chrismx4 chrismx4 is offline
The camaro is coming from a friend and doesn't have a motor or trans so i cant just go out and buy a v8 camaro i have to build a hot rod
Old 11-04-2010, 01:12 PM
Diognes56's Avatar
Diognes56 Diognes56 is offline
If you are going to change a V6 4th Gen to a V8, you have to change the engine/transmission crossmembers. Doesn't matter if it is the same year (95 would be a LT1) or later year (LS1s were from 98-2002). If you are swapping from the same year, you will atleast need the harness and PCM for the engine/trans you will be running. I think you would still need the PCM flashed/tuned so that it will communicate with the BCM since the 4th Gens used the passlock keys.
V6 exhaust won't bolt up. Rearend would be fine, not ideal but fine, it is the same rearend just (usually) with lower gearing and without the limited slip. Not sure on the fuel pump the 3.4L cars used, but it definitely wouldn't handle a LS1, not sure about an LT1.
David
Old 11-04-2010, 01:26 PM
ArisESQ ArisESQ is offline
It's not that you CAN'T do it that way, it's just going to be a lot more work than just buying a V8 and putting it in the car.
You'll probably need stiffer springs in the front of the car at the very least, you'll definitely need a new fuel pump, you'll need a new harness,trans cross member... It'll take a little research to get a list of everything together, and it isn't necessarily hard.... it's just gonna end up costing more than buying a car with a V8 in it already.
If this is absolutely what you want to do, I'd say you should get an LQ4 or LQ9 instead of the LT1 or LS1. It'll end up costing a little more, but it would be different at least, and (in my opinion) worth the extra expense and hassle.
As for the twin turbo stuff; doable, but costly.
Old 11-04-2010, 01:55 PM
chrismx4's Avatar
I just got to turbos the are the same the guy i am letting install them into the car is doing all of the tubing and mounting
Old 11-04-2010, 01:59 PM
98ssnova's Avatar
98ssnova 98ssnova is offline
so are you guys saying that a v8 will bolt right up without much modifying
I believe you need a v-8 cradle or subframe for the front
Old 11-04-2010, 02:25 PM
pokey64's Avatar
pokey64 pokey64 is offline
Just make sure you have a running/driving daily driver before starting this project. I'd hate to see you finish high school walking home.
Don't let me discurage you. I really don't know much about these specifc cars. If you want to figure this out and make it happen at 16 then you'll be way ahead of the curve in terms of knowledge/skill!
//Ed
//1964 Impala SS
//1966 Chevelle (Family Hauler)
//1969 Camaro (Hers...)
Old 11-04-2010, 02:37 PM
If you already have all that stuff worked out, then you'll be fine! Turbos have been done thousands of times, so there's a wealth of information available on plumbing and packaging that works.
That being said, and since it seems like this is the route you're definitely going, I suggest you try to locate an LQ4 instead of an LS1 for the swap. The LQ4's lower compression ratio and iron block would be more ideal for forced induction in stock form, and I think they can be found for pretty reasonable prices now.
EDIT: the more i think about this, the more i think you should just start off with a V8 car. even if you got a V6 rolling chassis for free, i think at the end of the day you'd spend either the same or less starting off with an original V8 car - and that's without even considering all the annoying little problems you'd find along the way.
Old 11-05-2010, 05:54 AM
Den69RS96's Avatar
Den69RS96 Den69RS96 is offline
Your not just gonna be able to bolt up a ls1 in to a v6 car. I was going to go the same route with my 96RS, but I decided not too. Before you do anything, google swaping a v8 into a v6 car. You could buy a nice running z28 for alot less than this swap will cost you. Also check with your dmv about v8 swaps.
In 1995, the z28 came with a LT1. If you go with a LS1 or LQ engine, your going to have to cut and modify the ls1 wiring harness to get the the car to run. it will be much easier to find a 1995 z28 LT1 motor, ecm, and wiring harness since it should be a plug and play. If you go the LS1 route, I suggest you find the wiring diagrams because this isn't a easy task if your don't know what your doing. Also, you will need the gauge cluster from a z28because the v6 gauge cluster will be way off. Also, the fuel pump will need to be replaced because the v8 pumps put out alot more volume and depending on the engine, you may or may not need a return fuel line.
LT1 and LS1 use different engine craddles, so you need to find one from a z28or go aftermarket from a company like BMR. Also if you go LS1, plan on replacing the steering rack and intermediate shaft because you will have fitment and alignment issues as the LS1 used a different set up. The v6 trannys have a different bolt pattern than the v8 cars, so you'll need a v8 tranny. Also the tranny crossmember are different. You'll need a different driveshaft as well. Don't forget the v8 front and rear springs as well. There will be a tone of little things that you'll need like a v8 radiator and fans, hoses, o2 sensors, other sensors,spark plugs etc. You'll also need headers, cats, and a different exhaust.
This stuff adds up quick so make a list of things you'll need and how much it cost.
69 Camaro, 350 .060 over, Trickflow heads, 4 spd, Flowmaster, Hotchkis suspension, Moser 12 bolt, Baer Serious Street brakes
Old 11-06-2010, 01:27 PM
Jano4's Avatar
Jano4 Jano4 is offline
As stated already, it would be much easier and cheaper to just start off with a V8 Camaro then doing the swap.
