Old 11-04-2010, 10:08 AM
chrismx4's Avatar
chrismx4 chrismx4 is offline
Smile Getting a 1995 camaro v6
I am new to the forms and i am 16 years old and i am looking at a 1995 Camaro with t tops. It needs a motor and trans. I was planing to put a ls1 into it with twin turbo for a every day driver. Also putting a manual trans into it please leave any help or ideas thanks.
Old 11-04-2010, 10:22 AM
jy211's Avatar
jy211 jy211 is offline
Fix it up make it run smooth, look great and just ride the car out.
Old 11-04-2010, 11:41 AM
Den69RS96's Avatar
Den69RS96 Den69RS96 is offline
I'm not sure of your financial situation, but swapping a v6 to a ls1 is going to cost alot of money and its alot of work. If you have the cash and time, I say go for it, but here is a list of some of the things you'll need. At the very least, you'll need the ls1, wiring harness, computer, front and rear coil springs, front cross member, tranny (clutch if 6spd), drive shaft, tranny cross member, radiator and fans, gauge cluster, fuel lines and a new fuel pump. You might need to swap over to a z28 rear end as well. It will be easier to locate a donor z28 with the same year as you'll car and the wiring will be easier to modify.
69 Camaro, 350 .060 over, Trickflow heads, 4 spd, Flowmaster, Hotchkis suspension, Moser 12 bolt, Baer Serious Street brakes
Old 11-04-2010, 11:51 AM
ArisESQ ArisESQ is offline
X2
If you know that you want to do an LS1 swap in a 4th gen, you'll be much better off just finding a Z28. And for the sake of affordability, I'll suggest that you just do a head and cam swap with some long tubes on an otherwise stock LS. That should give you WAY more than enough power to get you in some trouble and be a lot of fun
Old 11-04-2010, 12:18 PM
chrismx4's Avatar
thanks for the info i didn't know that it would be that much doing the swap hearing you guys talk about all the work im for that but not about buying all the other stuff. so what about just going to put a v8 camaro engine of the same year. thanks
Old 11-04-2010, 12:19 PM
jy211's Avatar
start out with a V8 and be done. Much much easier
Old 11-04-2010, 12:39 PM
Swain's Avatar
Swain Swain is offline
Put 100 shot of NOS and call it a day
Jason Swain
Build Link 68 Camaro
https://lateral-g.net/forums/showthread.php4?t=16865
Old 11-04-2010, 12:41 PM
chrismx4's Avatar
Exclamation
so are you guys saying that a v8 will bolt right up without much modifying
Old 11-04-2010, 12:54 PM
pokey64's Avatar
pokey64 pokey64 is offline
I took it as just buy a camaro with a V8 in it already.
//Ed
//1964 Impala SS
//1966 Chevelle (Family Hauler)
//1969 Camaro (Hers...)
Old 11-04-2010, 12:56 PM
BritishGreen68 BritishGreen68 is offline
do that^^^
Chris
Under construction-British Green 68 Camaro-
