Old 12-23-2010, 03:50 PM
FrankZ FrankZ is offline
Jason,I should have a pic but I will have to give it a look. In the meantime I can tell you that I mounted the regulator on a bracket to the center intake bolts w/a feed to each bowl(-6) and ran a -4 back to the tank bundled to the -8 supply. Hope that helps
Frank
Old 03-02-2011, 03:10 PM
67 455 Bird ragtop 67 455 Bird ragtop is offline
Just an FYI. In some sanctioning bodies, NHRA for one, the regulator must be no less than 6" forward of the flywheel if mounted in the engine bay. So the firewall is a no-no.
