Old 01-03-2011, 07:50 PM
Van B's Avatar
Van B Van B is offline
Best thing I did when building my house is putting radiant in the slab. I keep it at 55* all winter. It really doesn't make the bill much higher than if I let it go as cold as the weather dictates.
Jeff
99 Miata LS6
67 Camaro Street Fighter 599 HP L92-SOLD
Old 01-04-2011, 09:08 AM
g356gear's Avatar
g356gear g356gear is offline
I love mine. If you can, you should focus on increasing your insulation and keeping the heat you generate inside the building. I did the super insulation with 6" walls in my garage when I was building it and have the infrared on through the entire winter. It runs @ 95% eficiency so I dont even see much change in my heating bill. Maybe $10/month in the winter with the garage @ 60 degrees.
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 01-07-2011, 10:32 PM
rwhite692's Avatar
I installed a Sunstar 50K BTU in my shop, it is "closed" chamber and vents outside...
It's way overkill considering the local climate here, but I love the thing when it's chilly....and being 20 feet long, it gives great "coverage" to the space....
I set the thermostat to come on if the temp gets down to 62 or so and I just leave it there.
Project update thread here:
My Lateral-G Page
My Shop Build:
Old 01-07-2011, 11:13 PM
Really....????!!! When it gets all the way down to 62*........ What a DB!!
Old 01-08-2011, 10:35 AM
Fluid Power's Avatar
62? I would be working in the shop with the doors open!
Nice!
Darren
Old 01-08-2011, 10:47 AM
rwhite692's Avatar
I know, sad, ain't it?
Former New Yorker...I used to be able to tolerate the cold, no problem.
Moving to Kalifornia in the mid-90s changed all that.
My Lateral-G Page
My Shop Build:
