Old 01-31-2011, 11:39 AM
JustinB's Avatar
JustinB JustinB is offline
Originally Posted by BBC69Camaro View Post
Snap-on also has a interesting flywheel turner tool:
http://buy1.snapon.com/catalog/item....&group_ID=1619
Sometimes nice if the crankshaft bolt isn't easy to get a socket on, or you need to rotate it under the car and don't have a friend handy to help.
One of my favorite tools in my box. Use it all the time!
Justin Butler
69 Camaro, 68 Camaro, 05 GTO.
Old 01-31-2011, 03:12 PM
lutzy lutzy is offline
Got it out! wasnt that bad..It would of been easier with a extra set of hands though..im gonna wait for my 5 speed kit patientley for 2 weeks now..and if anyone needs a TH400 complete let me know..it only has 97 miles since installed...
Old 01-31-2011, 04:57 PM
Rybar's Avatar
Rybar Rybar is offline
Nice job, let's see some pics of the car that you picked up.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 01-31-2011, 05:55 PM
Old 02-02-2011, 08:27 PM
Devil Dog's Avatar
Devil Dog Devil Dog is offline
Thumbs up TKO Swap
Hey Lutsy, i just did the TKO / TH400 swap myself. I found that the higher you can get the car the easier to perform the install.
Quick tip... leave the clutch/pressure plate off for mock assembly which you will (should) do to measure, measure (yes measure twice) to mark where your shifter hole will go.
Once the mark was made, I used a new factory lower boot and stock 69 Camaro boot retaining ring to trace the actual location of the hole.
I wanted the car to look as if it came from the factory as a 4 speed.
One more thing... I was able to save on a driveshaft by purchasing a new Spicer Yoke and a used Dynotech driveshaft on ebay. My drive shaft was 46" center of u-joint to center of u-joint. Total cost with new 1350 U-joints was under $125. Good luck!
Marco
Semper Fi
Old 02-06-2011, 09:22 PM
Here's the first ride..
https://www.youtube.com/watch?v=IN76Z...youtube_gdata_
