Old 04-11-2011, 07:15 PM
MODO Innovations's Avatar
Originally Posted by 67Rally View Post
I would hit all the subframe mounts with something like PB Blaster a couple times during the week before pulling them out. Loosen a little, tighten a little, loosen, tighten until you know for sure they aren't seized up.
This is excellent advise. It can save the nuts on the body from damage.
Originally Posted by mrr1999 View Post
It will be a rolling chassis. Thanks for the the great info. I imagine, once the brake lines are out and any grounding wires are removed, it should come right out. Does that sound right?
Yep, its sounds like you got it.
Shannon
Modo Innovations
940-391-9002
Old 04-11-2011, 09:03 PM
Blake Foster's Avatar
you get that info i sent you?
was it any help?
Blake Foster
www.speedtechperformance.com
Old 04-12-2011, 03:20 PM
mrr1999's Avatar
mrr1999 mrr1999 is offline
No, I didn't get anything.
Mike - Las Vegas, NV
69 Camaro - in process
70 Chevelle SS396
69 Mach I
Yes...Chevys and Fords
Old 04-12-2011, 05:31 PM
Is the email in your profile correct?
Blake Foster
Old 04-13-2011, 10:10 AM
mrr1999's Avatar
Yes, sir.
70 Chevelle SS396
69 Mach I
Old 04-23-2011, 10:25 PM
David Pozzi's Avatar
If the A arms & steering box is off, place the floor jack to the rear of the main crossmember, the rear tails of the sub will want to drag on the floor as you pull it out but you can push down on the front frame horns and pretty much balance it. Support on jack stands each rocker panel near the pinch weld. I put a 2X4 on the jack stands to give it some grip.
David
http://www.PozziRacing.com
Old 04-25-2011, 02:49 PM
mrr1999's Avatar
Thanks, David. I appreciate the input.
70 Chevelle SS396
69 Mach I
Old 04-25-2011, 04:11 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Couple floor jacks, an engine hoist, and some snowmobile dollies and you're all set.
https://lateral-g.net/forums/show...t=26575&page=6
My LS7 69 Camaro
Old 04-26-2011, 09:05 AM
Here.... You do it just like this!
