Old 07-13-2011, 09:20 AM
Rick D's Avatar
Rick D Rick D is offline
Originally Posted by David Pozzi View Post
The spherical bearings eliminate binding as the car rolls. With rubber or Poly bushings, the rear get's stiffer and stiffer with every degree of chassis roll due to bushing compression. This can cause corner exit oversteer.
Pot holes and tar strips will be felt more with these, but the rear feels more precise. Type of tire matters too, a tire with more tread feels pretty good on the street, but 100 tread wear tires with very little tread feel harsh.
David
David, So would say that a street car that will see a track or auto cross a few times a year benifit from these or not really?
Rick
Old 07-14-2011, 01:35 AM
RSZ28 RSZ28 is offline
Originally Posted by Hotchkis View Post
Roberts68 – Thanks for being fair with your “marketing consultation” and also for pointing out the PTFE. We’ll have our web guy look into that.
He looked into it so good the website is offline .
Looking forward to these .
Old 07-14-2011, 09:43 AM
garymac69's Avatar
garymac69 garymac69 is offline
Can we get before and after test results on these bushings?
Old 07-14-2011, 11:24 AM
GaRys69 GaRys69 is offline
So would this be an improvement over greased up Delrin bushing shackles?
Gary Rys
69 Camaro
Old 07-18-2011, 12:33 PM
David Pozzi's Avatar
There is benefit, I'm not sure how much. When we switched to this type (Cat 5) the rear felt more precise & it let you know what was going on back there a little better. We have this Hotchkis system on Deanna's second gen Camaro which is winning.
In a back to back test, comparing it to Delrin/Poly bushings, I think the difference would be small. No way do you ever want a solid delrin or aluminum bushing up front on a leaf spring. It would cause corner exit oversteer due to binding. A solid bushing on the rear leaf eye is not so bad, but a stock front & poly rear on the leaf eyes is next best to this system.
David
http://www.PozziRacing.com
Old 01-15-2012, 06:59 AM
onelapduster onelapduster is offline
Just trying to connect the dots here.
As far as a leaf spring rear suspension is concerned, this setup with an adjustable sway bar, PTFB comp rear leafs, would be the cats meow as far as a leaf sprung suspension could be for a autocrossed car that gets driven on the street.
How would a watts link affect a setup like this? Would it interfere with the already limited side to side movement?
Old 01-15-2012, 08:26 AM
Bryce Bryce is offline
A watts link defines a roll center the leaf springs also define a roll center. If you matched these roll center you would have less bind.
I would use these and a spherical in the front spring eye.
