Old 08-07-2011, 06:32 AM
LarryC5 LarryC5 is offline
Sieg,
Again, great pictures. I now have a very clear picture of what is in front of me. Having done a TKO swap before the basics were there just the damn tunnel and firewall had me a little nervous.
For the record, I'm dropping in a 540ci BBC on SMBC engine frame stands. Not sure if this will add to the fun or not.....
Congrats your install......
Larry
Old 08-07-2011, 08:20 AM
Sieg's Avatar
Sieg Sieg is offline
Originally Posted by LarryC5 View Post
Sieg,
Larry
Be patient and enjoy the challege. SBC / BBC drivetrain centerlines shouldn't be much different
Old 08-09-2011, 01:55 PM
69z11's Avatar
69z11 69z11 is offline
Default t56 mag
I am putting in a 496bb w 650hp/560 torque. Want to put in tranny to handle and considering t56 mag. Will the 6 spd fit in the factory console with no cutting. My car is a 69 vert born as a 4 spd.
Old 08-09-2011, 02:42 PM
Sieg's Avatar
With the Hurst "Blackjack" shifter and offset shifter mount, yes. The T56 Magnum is supposedly rated/warranted for 700 ft. lbs.
Old 08-09-2011, 03:10 PM
69z11's Avatar
Thank you!
Old 08-10-2011, 08:01 AM
6D9 Matt's Avatar
6D9 Matt 6D9 Matt is offline
Yes that should work (or I hope). I have that exact tranny (and shifter, etc) being installed into my Camaro right now, hope to get it back this week.
'69 Camaro
416ci / T56 / 9"
Turbo in the works...
Old 08-11-2011, 04:54 AM
69z11's Avatar
And you have the factory console?
Old 08-11-2011, 05:43 PM
6D9 Matt's Avatar
Yessir
'69 Camaro
416ci / T56 / 9"
Old 08-13-2011, 06:54 AM
69z11's Avatar
I'm ordering one. Let me know how your install event goes. Good luck and have fun!
Old 08-19-2011, 06:29 AM
Sieg,
I did a trial fit with eng and bell only last night. The clearance needed around the trans tunnel where the bell resides need massaging on my car as well. How much massaging did you do? I'm thinking I need to go 1" or more. The clearance you achieved looks to be far greater than initially I think I can get without pulling out my plasma cutter...
So, what is the best approach tool and technique wise to "massage" the tunnel area? BFH for starters I assume.
Regards,
Larry
