Old 07-23-2011, 08:04 AM
LarryC5 LarryC5 is offline
Default T56 Mag Shifter Location 69 Camaro
Question:
I'm about to trial fit a T56 Mag LS trans into my 69 Camaro with a BBC. The T56 Mag apparently has two possible shifter locations by rotating the shifter/plate by 180.
What is the best location for the shifter to be mounted (forward or aft) ? I will be using a console if possible. I want to have the shifter in the most correct location before bolt up the trans to the engine then go cutting holes in a clean trans tunnel.....
Lastly, the trans as delivered has the shifter mounted in the furthest rear most part of the trans.
Thx
Larry
